Eldarion and Bruce's build of Bob's Energy Converter
Started by eldarion, July 27, 2007, 12:58:39 AM
eldarion
Quote from: tao on July 29, 2007, 04:53:43 PM
Quote from: eldarion on July 28, 2007, 09:44:39 PM
Well, I just finished design and construction of the $20 bias supply!  It provides 150-200V from a 13.8V source, depending on load.  Plus, it only draws about 5 watts!
I have rescaled the meter in the picture to read in volts x10.  As you probably have guessed by now, I am a bit crazy about metering and instrumentation--if something goes wrong, I want to know exactly where with a glance, not have to spend the next 30 minutes probing around with a multimeter... ;D
Eldarion
Eldarion,
Nice work man, would you mind drawing up a little schematic for us of your bias supply?
Thanks
Sure!  Here you are...
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
MeggerMan
Hi Eldarion,
I have 3 x ali cases for the dds 20 boards I have built.
Hammond 1455 series
http://www.hammondmfg.com/pdf/1455L1601.pdf
Like you, I have been wondering how to get the electronics into the centre of the TPU.
I hope to put two cases back-to-back and the mosfet driver and mosfets under that.
I will need to extend the controls using some clear tubing and chop sticks or something to press the buttons.
Also using a really big 15" TPU may help things.
Rob
eldarion
Quote from: MeggerMan on July 29, 2007, 06:10:22 PMAlso using a really big 15" TPU may help things.
Yeah, I think with the amount of circuitry I have here that may be the only thing that can help! ;D
Here is a pic of the finished TPU, all hooked up but for the collector to its load.  I still have to figure out a way to limit the current drawn by the magnetic bias coils, as when I hook them up to the battery on the right (all in series), the jumper leads get extremely hot in a few seconds.  Given that there is only 0.29 ohms of resistance in those coils, I am probably drawing nearly 41.3 amps (410 watts)!!!  That is a surefire way to not get overunity performance! :D
Any thoughts?
P.S. I won't be firing this up tonight; I'll save that for tomorrow when I have a clearer head.  Given that there is almost 150V floating around in this thing, I am liable to get zapped. :P
Eldarion
-- Thomas Paine
Bob Boyce
@Eldarion
You should only need a few hundred milliamps at most on that magnetic bias winding. You can use a simple PWM to drop the current . You really want the ability to dial the strength of that magnetic bias anyways.
Bob
eldarion
Quote from: Bob Boyce on July 29, 2007, 11:05:01 PM
@Eldarion
Bob
Bob,
Thanks for the PWM idea; I had not thought of that.  I will stick another MOSFET on my driver board for variable bias control, since I have to re-do the high voltage bias anyway.
I take it the magnetic bias can be pretty weak, and it does not have to be steady on, i.e. it can (should?) be pulsed?
Eldarion
-- Thomas Paine
