Longitudinal wave research
Started by MarkSnoswell, July 28, 2007, 06:31:29 AM
MarkSnoswell
I was just reviewing the longitudinal wave work of Stanislav & Konstantin AVRAMENKO
http://www.rexresearch.com/avramenk/avramenk.htm
and of Prof. Dr-lng. Konstantin Meyl
http://www.meyl.eu/go/index.php?dir=10_Home&page=1&sublevel=0
While this work in undisputable and of fantastic potential both systems require a single wire or a good ground connection between transmitter and reciever. This is a big problem if you want to power a portable device like a cell phone... or if you want to develope a communications network based on longitudinal waves... I think I have a very simple solution to this :)
This will be very easy and cheap to test. As part of my ongoing research into the basics I plan to test simple new longitudinal wave transmitters and recievers when I get back (late August). In addition to being a fundamental part of TPU like devices there are many opportunities for lonngitudinal waves in the transmission of power and in telecommunications. If anyone is interested in participating in tests in this area just let me know.
Dr Mark Snoswell.
President of the CGSociety www.cgsociety.org
Bruce_TPU
I found this nice description at a link off of one of Mark's aforementioned sites.
Motorcoach1
IN Teslas single wire power tranmission the LMD coils were passive to the collector if i can find the diagram I'll post it the coils were not grounded , just left open but the wire off the coil was distributed along the leingth of the wire (collector or the transmission line ) only the antenna was grounded between the tank capicotor to ground. no other ground. coils were run static once started and power removed (spark gap to the cap and back fed to the coils , when entergized the power was cut off due to the static feild generated.
Bob Boyce
In my replication attempt of a larger scale Tesla Radiant Energy Collector, a large spiral coil at the top of a 30' mast, was connected to the hot side of a primary tank coil via an adjustable spark gap. The cold side of the primary tank coil was connected to an identical spiral coil buried in the ground around the base of the supporting PVC mast. A ground rod was connected to the outside point of the ground spiral.
One thing to be sure, winding longitudinal energy coils with stranded wire seemed to put the kabosh on those coils being able to carry longitudinal currents well. I made that mistake with the larger guage wires first used in the intermediary bifilar coils. They just would not tune well at all.
Bob
Jdo300
Hi All,
This issue of the receiver being grounded has always bugged me. I have always wanted to build a Tesla wireless power transmitter just to play with it. I was especially inspired by the one that Marco posted on the forum a while back. I'm very curious to see what would happen if you were to have more than one receiver pulling power from the transmitter. Would the transmitter 'perceive' the load from the receivers? If not, then one could conceivably have power multiplication simply by adding more receivers for the same source. Or, you could put the transmitter and the receiver together as one and use feedback to increase the gain of the system.
God Bless,
Jason O
