Bob's Booster On Demand (BOD)
Started by yikes, July 28, 2007, 08:11:13 PM
Draco Rylos
@yikes
Have you though about changing the timing? you may have to change the timing of the engine to get it to fire just after TDC. That's what I have been reading here and on other sites on the net.
We are the BORG..... We will add your biological and technological distinctiveness to our own. Your culture will adapt to service US. RESISTANCE IS FUTILE
yikes
Quote from: yikes on August 07, 2007, 06:30:41 PM
I still need to play with the timing, but it runs as good as ever.
Umm, yea, I thought about it.
But to change the timing to atdc, I need to make lots more H than I am now.  These are just baby steps, soon we can run.
yikes
Took the mower booster apart to clean it out.  Wasn't too bad, I was surprised.  Took the cells apart, added another washer (nylon) to separate the cells more, total now 6 mm and added two more plates.  Then I wanted to seal it up, but I also want to be able to change things around in the next couple of days.  The answer:  duct tape.  Yep, I found a weather resistant duct tape and carefully? taped the cell.  Ran it for an hour and it held up, so I put it back together and put it on the mower, fired it up and let it run for another hour.  In a couple of days I'll take it apart and report on how the tape held up.  Hey, it's quick, easy, cheap and of course the best part,,,I get to use more DUCT TAPE.
ZeroFossilFuel
My next electrolyte canister will look exactly like this, only white and taller. How are you sealing the threads of the cleanout cap? Is that where you wrapped the duct tape?
My public PGP key. Please help support my work. Donate by PayPal
yikes
Hi Zero, great flow measuring bottle you developed.  After seeing the video I immediately ran to the store for a liter bottle.  I have seen no better device.  Good work.
At this stage, I'm not too concerned about the leakage at the threads.  I once tried to stop it with vaseline (don't do that).  Vaseline coated everything inside and it took a long time to clean it all out.  Goop could do it and then scraped off when you needed to take it apart.  There are lots of other ways also.  But for now, I need to be able to take it apart often to change things so I don't bother with sealing.
Question:  Why is yours going to be taller?  Are you planning on long plates? Like in my car booster?  Just curious.
About the duct tape.  No I wrapped the plates with the tape.  I'll take it apart today and get a picture for you.  I want to make some more changes anyway.
I enjoy watching your video, but at 28k it takes forever to download, ha.
