Eldarion's FPGA-based TPU controller
Started by eldarion, July 29, 2007, 11:24:39 PM
Bruce_TPU
Hello All,
I have finished my first Bob Boyce coil!   ;D
The first picture is of the six primaries, wound around the entire coil.  I wound 25 turns per primary.  23 actually would have fit a little more comfortable.  I am starting to tape over the primaries with #35 blue electrical tape.
The second picture is of the yellow motor tape wound over that.
The third picture is of the finished coil.  All of the fiberglass sleeves are on, everything is properly labled and the final wind of #35 electrical tape.  The core is solid, waxed and taped.  No way any windings can move while in transit.
I then placed it into a special case, which will then be packed in sytrofoam peanuts and a box, and shipped Monday, to Eldarion, where it will be linked up with Thor!   ;)   Next week ought to be very interesting around here!
Also Monday night, I start winding my own coil.
Cheers,
Bruce
weri812
looks GOOD!!!!
Bruce
on to the next level
wer
PUT YOUR MIND IN GEAR BEFORE  YOU PUT YOUR MOUTH IN MOTION
eldarion
I am in the process of designing a custom PC board for this system.  My current thoughts are:
1.) It should be small enough to fit in the center of the toroid--probably long and skinny, 2 inches in width?.
2.) I will be including the ability to drive up to 12 primaries.  Whether or not I even populate those parts is something to be decided later...
3.) Along those lines, the system would be able to drive two 3- or 6-primary coils for extra power output.
4.) I will be adding an Ethernet port for remote control and monitoring purposes if possible, in addition to the VGA and PS/2 ports.
I would then be able to sell a ready-to-run controller, just add your own IGBTs or MOSFETs.  Would there be any interest in something like this?  (I will be making up at least two PCBs for sure, one for Bruce and one for me).
Obviously I will wait to order any boards until I at least have the prototype operational. ;)  I would like to keep the cost below $150 if possible.
Eldarion
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
weri812
hello Eldarion
that sounds very nice.
with 2 sets of controllable outputs  you can use 2 cores.
as you know i am using Bob's pwm3f-hd
still working on the variable hv potential and  a variable DC bias supply
i also had in the back of my mind to build a second core to
parallel with the first one.   plan to mount in a metal box.
wer
