single phase power savings
Started by jjbeamish, July 30, 2007, 08:57:24 PM
jjbeamish
Moderator, please delete this post. Thanks
Thanks,
Jason
ashtweth_nihilisti
Quote from: wattsup on August 05, 2007, 06:54:43 PM
@mramos
If you are using a 1.5 hp well pump in a home setting, this means your well is very deep. I have been in water treatment for over 20 years and have good experiences with pumps and wells, and that size pump is larger than ordinary indeed for a home.
So if you have a very deep well, and you RV your pump, you will get about 3/4 hp or probably less once it is RV'd and this may not be enough to give your home the proper water pressure.
Also, you should already have a pump control unit and in there you should already have a start capacitor and some control electronics.
So be careful if you play around with this type of pump with RV. I personally would not try RV for the first time on my well pump.
Wattsup, the Rv can deliver any horse power you want using a Freq drive
http://video.google.com.au/videoplay?docid=9089608413203959523
Catch is our HP is the most efficient power management, more Freq driven RV's should be done by others.
?If you create your own electricity, heating and water systems, you create your own politics. Maybe that?s what they?re afraid of.? ?? Michael Reynolds
http://www.panacea-bocaf.org
http://www.panaceauniversity.org
http://www.geocities.com/glorybangla/cqtes.htm
