Exactly WHAT is the dreaded sticky spot.....
Started by beedees, August 04, 2007, 05:13:02 PM
beedees
...and any great advantage in eliminating it?
tropes
BDBD
The "sticky spot" occurs when the rotor magnet(s) and the stator magnet(s) are in a state of equilibrium. The repulsion or attraction of the rotor will move the rotor a portion of a full rotation (360 degrees). The rotor stops when the same repulsion or attraction prevents the rotor from moving .
This is best illustrated when a single stator magnet repels a single rotor magnet. If the stator magnet is not removed when the rotor magnet rotates to the proximity of this repelling  magnet, it will stop and be repelled before it reaches 360 degrees.
Adding magnets to the stator or rotor make no difference as the stator magnets will act collectively as one magnet and the rotor magnets will also act as one.
Duranza
The advantage of eliminating it will yield a working PM motor :-)
The only way to Validate is to Replicate!
tropes
Quote from: beedees on August 04, 2007, 05:13:02 PM
If we could eliminate the "sticky spot" most of us in this group would have a perpetual motion machine.
norman6538
One can get magnets to do work but then they are stuck such that
it will take as much or more force to get them apart. Even the smot
google video looks like it gets past the sticky spot but it does via
gravity dropping the ball down into the dish. So there is no net
gain. Yes it goes up hill but no net gain.
In the case of my pendulum that swings higher than its dropped point
it gets away from the sticky spot and drops back to 6 oclock and is not
stuck but so far I have not been able to take power off and use it.
No pendulums do not normally act that way.
Norman
