Permanent Magnet Lifters with on/off switch?
Started by ryanjrx7, August 14, 2007, 01:30:50 PM
Honk
Well, the MEG did not work, the other devices I don't know of except Flynn, but I have my hopes for the Hilden Motor.
The MEG might have failed due to bad electronics. The coils of the MEG must be operated at modest frequencies
with small losses to avoid the sluggish flux field build-up of the high inductance coils.
My Flux Booster Controller might do the trick on a MEG like transformer. I does increase the coil efficiency about 1500%.
Once I have finished the controller tests on the Magnet Valves I might try to build a Hilden-Brand Valve MEG.
Let's wait and see......
Magnet Power equals Clean Power
JamesThomas
Quote from: gn0stik on August 16, 2007, 12:42:51 PM
They're called radus boots, and they are no longer used by NASA, instead "shuffler" boots have taken their place, presumably because of fears of power loss, or...?  Supposedly they use plates and electromagnetic coils to redirect magnetic flux.
Thanks, gn0stik. Ya I'm pretty sure this is it. A permanent-magnet memory device the utilizes low energy for switching.
We are not what we believe ourselves to be.
gaby de wilde
MEG
hilden-brand motor
Quote from: ryanjrx7 on August 15, 2007, 06:54:33 PM
lol, not looking for any problems.  I've already got a big one that keeps me awake a night involving a certain machine that makes motion perpetually... should come up with a name for it  ;)  Gyula you are quite the character, I must say.  Thanks for the links!
YES! This is a valuable clue IMHO, what I can make from the insomnia vision it is that we have 2 possible futures as a species. We humans are not enlightened enough to envision the future in detail but we can absolutely have a feeling about stuff around the corner with an accuracy above zero. I think we are either going to create perpetual motion or we will make nuclear war. Something subconscious is motivating me. The answer is easy to find, there is a whole parade of free energy machines. It's just that people enjoy demotivating each other and continue to guess what something is while real information is available to them. Lets do try add some extra information before posting?
I also continue to suggest each one of you creates a publicly accessible website about the flux switching topic. I'm not going to search your 100 000 old posts for little tidbits of info, asking me to waist my time?  This is really not to much to ask if you want others to share their stuff. Some one may take you seriously... imagine that one!
My flux swithching page is below. As you can see I have 6 links on there. (woo hoo 6 whole links) I will add some more links to this post then I will add a link to some forum topics to the page, whole minutes of hard work, I know, I know. :D
links
http://magnetmotor.go-here.nl/flux-switching
text
http://magnetmotor.go-here.nl/text
peoples
Charles J. Flynn
Jack Hildenbrand
KeelyNet - Emery Version - Leedskalnin Perpetual Motion Holder
Radius boots
tom berden: the astronaut's magnetic boots
*Raymond j. Radus patents*
AC/DC or DC/AC Converter system with improved AC-line harmonic reduction
Abstract
In a transformer-rectifier converter system, at least one inductance is inserted in the commutation path of two adjacent diode or thyristor devices in a cluster of three devices related to a common DC polarity pole, the reactance due to such inductance being sufficient to lengthen the commutation overlap thereby to minimize AC line harmonics. The invention is applicable to AC/DC as well as to DC/AC conversion.
Patent number: 4366532
Filing date: May 11, 1981
Issue date: Dec 28, 1982
Inventors: John Rosa, Raymond J. Radus
Assignee: Westinghouse Electric Corp.
http://www.google.com/patents?id=edo9AAAAEBAJ
Transformer for low distortion rectifier system
Abstract
A coil for a 12-pulse transformer-rectifier apparatus assembled on a three-leg magnetic core comprising a half primary winding sandwiched between two half secondary windings of substantially the same height as the half primary winding. A pair of coils associated with one leg of a three-leg magnetic core in a 12-pulse transformer-rectifier, are oriented in opposition to one another, and have all their terminal conductors extending parallel to one another with transversal connectors in closely-related parallel planes.
Patent number: 4482945
Filing date: Nov 29, 1982
Issue date: Nov 13, 1984
Inventors: Joachim E. Wolf, Paul H. Watson, Raymond J. Radus
http://www.google.com/patents?id=x8csAAAAEBAJ
Secondary circuit breaker for distribution transformer with indicator light switch mechanism
Abstract
A secondary circuit breaker for a distribution transformer characterized by electrical inductive apparatus within an oil-filled housing, and circuit interrupter for controlling current flow through said apparatus and comprising a releasable latch arm, trip means operable upon overload conditions to release the latch arm, a latch lever between the trip means and the latch arm, and a signal light circuit for activating a signal light when current through the circuit breaker exceeds a low signal overload value. That is less than the trip value.
Patent number: 4554524
Filing date: Aug 23, 1984
Issue date: Nov 19, 1985
Inventor: Raymond J. Radus
http://www.google.com/patents?id=RaU5AAAAEBAJ
MAGNETIC MEMORY DEVICE
Patent number: 3165723
Filing date: Jan 19, 1962
Issue date: Jan 1965
Assignee: Westing
http://www.google.com/patents?id=3PllAAAAEBAJ
Patent number: 3569947
Filing date: Jun 16, 1969
Issue date: Mar 1971
Inventor: Raymond J. Radus Monroevilk
Assignee: estinghouse Electric Corporation East Pittsburgh
http://www.google.com/patents?id=89NzAAAAEBAJ
more patents
http://magnetmotor.go-here.nl/flux-switching/patents
magnetic memory device - 3569947
MAGNETIC HOLDING DEVICE -  3184654
Switchable permanent magnetic holding devices - 4055824
Magnetic base - 4251791
Magnetic holder - 4465993
Method and apparatus for coil-less magnetoelectric magnetic flux switching for permanent magnets
Methods for controlling the path of magnetic flux from a permanent magnet and devices incorporating the same - US 6246561
MAGNETIC HOLDING AND ALIGNING DEVICE - US 3304527
SENSING DEVICE FOR AUTOMATIC BRAKE SYSTEM INCLUDING INERTIA SWITCH WITH MAGNETIC HOLDING MEANS - US 3886339
ELECTRICAL SWITCH HAVING MAGNETIC HOLDING MEANS - US 3243542
Magnetic tool holding and storage apparatus - US 6006906
MAGNETIC HOLDING DRUM - US 3581257
DYNAMOELECTRIC MACHINE SHAKING AND MAGNETIC HOLDING ARRANGEMENT - US 3176174
GRANZOW MAGNETIC HOLDING UNIT - US 3294433
MAGNETIC HOLDING DEVICE - US 3184654
MAGNETIC BOBBIN HOLDING MEANS - US 2561155
CHANNEL FOR HOLDING MAGNETIC PACK - US 3109967
Magnetic nail holding device - US 4829855
MAGNETIC LATCH HOLDING MEANS FOR A SELVAGE KNITTING NEEDLE IN A NARROW WARE LOOM - US 3601160
Magnetic insert in jaw plate for holding vise parallels - US 6361034
GUN REST WITH MAGNETIC HOLDING MEANS - US 3041938
Rotating housing and anode/stationary cathode x-ray tube with magnetic susceptor for holding the ... - US 5274690
MAGNETIC FASTENER-HOLDING DEVICE - US RE24066
Permanent magnetic holding arrangement, particularly for temporary holding of ferro-magnetic parts - US 4401961
MAGNETIC HOLDING MEANS - US 2209809
VIBRATION ACTUATED SWITCH WITH MAGNETIC HOLDING MEANS AND ARMATURE RESET POSITIONING MEANS - US 3794786
Adjustable quick release magnetic holding assembly - US 4754532
MAGNETIC HOLDING MEANS IN A SURFACE PLATE DIMENSIONAL MEASURING APPARATUS - US 3723927
MAGNETIC HOLDING DEVICES - US 2923865
Switchable permanent magnetic holding devices - US 4055824
Magnetic holding device - US 6086125
MAGNETIC HOLDING DEVICE - US 2955239
MAGNETIC DETACHABLE HOLDING DEVICE - US 2943246
MOVABLE MAGNETIC BOWLING PIN HOLDING APPARATUS - US 2848235
MAGNETIC HOLDING DEVICE - US 2854273
Brackets and methods for holding wires utilizing magnetic force - US 6855890
MAGNETIC FASTENER-HOLDING DEVICE - US 2630036
Magnetic holding device - US 4652845
Magnetic work-holding device - US 4356467
Magnetic socket holding and storage apparatus - US 5080230
Part holding press tool with non-magnetic part holding mechanism - US 5539968
CONTAINER FOR HOLDING MAGNETIC TAPE ON EDGE AND HANDLING DEVICE THEREFOR - US 3588377
Magnetic holding device - US 4072920
Magnetic holding device - US 6614337
CONVEYOR WITH MAGNETIC ARTICLE HOLDING MEANS - US 3844401
Electrical machine
Static free magnetic holding and release means - US 4052883
Switchable permanent magnetic holding device - US 4419644
Remember that patents cost money. The list represents a lot of money and a lot of time. Those URL's didn't just find and type themselves. The concept of flux switching is very easy to understand, now lets learn everything that is already hacked.
There has to be at least a month worth of insomnia right here, enjoy!
:D
blog  | papers | tech | inventors  | video
Nali2001
This might be of some interest
Static magnet dynamo for generating electromotive force based on changing flux density of an open magnetic path
http://www.google.com/patents?id=lK8XAAAAEBAJ&printsec=abstract&zoom=4&dq=5926083
Honk
It looks very similar to both the Flynn and Hilden-Brand devices in most ways.
And many flux swithing patents do share similarities.
If anyone manage to make a working MEG there must be a ton of lawsuits waiting to be filed.
Everybody wants a share of the big money cookie.
