The return of the Hungarian: FREE ENERGY from Wave-Fields...
Started by tao, August 17, 2007, 03:29:35 PM
disclosure
Hi guys,
I happened to be on overunity.com and found this thread... My mother tongue is Hungarian and I have some engineering background so I prepared a translation for you in English. I hope it helps:
"The device which forms the basis of this invention enables - with the help of passive structural units -  the followings: Place two or more elementary radiating sources side by side and in this radiation field favourably superposition these fields to increase the energy of the result wave and convert this surplus energy into other energy form(i.e heat) in order to utilize it. By the export version of this device the elementary radiating sources into which the input signals flow and the elementary radiating sources which receive the waves are placed inside a properly positioned reflecting surface(1). The phase centers of of the elementary radiating sources are placed in the focus points(F1, F2) where they are connected through dipol(2) wires. If the elementary radiating sources are of other types they can be connected - with the proper phase alignment- through coaxial or stripe wires(3). These wires(i.e 2,3) connect the elementary radiating sources and provide the output based upon the incoming/outgoing high frequency signals."
A tal?lm?ny t?rgy?t k?pezÃ...‘ berendez?s(ek) lehetÃ...‘v? teszi(k) passz?v szerkezeti elemekkel, k?t vagy t?bb, egym?shoz k?zel elhelyezett, elemi sug?rz?val kisug?rzott elektrom?gneses hull?mok sug?rz?si ter?ben, azok kedvezÃ...‘ szuperpon?ltat?s?val, az eredÃ...‘ hull?m energi?j?nak megn?vel?s?t ?s ezen t?bbletenergia k?zvetlen, vagy m?s energi?v? (pl. hÃ...‘energia) t?rt?nÃ...‘ ?talak?t?s?val k?zvetett hasznos?t?s?t. A berendez?s kiviteli v?ltozatain?l a bemenÃ...‘ jelet kisug?rz? elemi sug?rz?k, ?s a hull?mokat vevÃ...‘ elemi sug?rz?k, egy alkalmasan kialak?tott reflektor (1) fel?let belsej?ben, f?zisk?z?ppontjukkal a f?kuszpontokban (F1, F2) vannak elhelyezve, ahol ezeket a dip?lokb?l (2) ?ll?, vagy m?s t?pus? elemi sug?rz?kat, megfelelÃ...‘ f?zissal koaxi?lis, vagy szalag t?pvonalak (3) kapcsolj?k ?ssze ?s vezetik ki, a bemenÃ...‘ ?s kimenÃ...‘ nagyfrekvenci?s jeleknek megfelelÃ...‘en.
Cheers,
Greg
AhuraMazda
tao
Quote from: disclosure on August 24, 2007, 07:42:50 AM
Hi guys,
Cheers,
Greg
Awesome,
This helps a lot, thanks for the translation!
acerzw
Hi,
    Since I'm no good at electronics, I have done a bit more research. Don't know if this is useful or not but I have located contact details which I believe might be for the Hungarian inventor, Janos Vajda. He appears to be the Head of Department in the Office for EU Projects and Grants at the University of Debrecen in Hungary.
address: 4032 Debrecen, Egyetem ter 1
contact email: rtd@admin.unideb.hu
and the website for them:
http:/wwwold.unideb.hu/rtd/
The source document for his contact details can be found at:
http://docs.tetalap.hu/hufp6/fp6contact.pdf
and contains telephone and fax numbers in addition.
One of the group may wish to initiate contact though if this is him I understand from the Hungarian site that he had a lot invested in this so unsure how he would take an approach re his invention.
In a Holographic Multiverse everything is smoke and mirrors!
What is Reality? Improve yours: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13459
A shorter version for the very open-minded: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13866
13thHouR
Quote from: AhuraMazda on August 24, 2007, 10:33:43 AM
@13theHour,
Thanks for the link. Following the info, I was led to Background Field Theory. I recommend these to very one:
http://www.backgroundfield.com/index_1.htm
http://www.backgroundfield.de/detected_1.htm
http://www.zero-point-energy.com/efevbf_1.htm
AM
Yep I know of Carlos's work, I wonder where he got the ideas from  ;) I am not blowing my own trumpet but I have indirectly had lot of influence over the years on various publications
Background Field Theory is a good representation of the finite, but stops short of truly pushing the boundaries and explaining with a reversible process, what occurs beyond an event horizon and how this affects our finite space time.
It's always promising though to see people thinking outside of the box, I just wish that when they decide to push the boundaries that they define usable values to work with.
Then theory or conjecture becomes a practical tool rather than just a construct of informed thought.
Background Field Theory is a good stepping stone in thinking alternatively
