Stanley Meyer replication with low input power
Started by hartiberlin, August 18, 2007, 04:39:57 PM
Gheller J
Duranza>>>>
ur gap in between d pipes is 1.905mm viz more than what stan or Dave used     Ravi's is 1/3rd of urs>>>less than 0.670mm this cud reduce ur efficiency compared to any of them. Check stans canadian patent spacing table ref for efficiency to ur size.
SwinG>>>>
Check if dis helps
http://www.edn.com/contents/images/101101di.pdf
Gh. J.
Duranza
Yeah i know gheller, but it's what i had in hand and i'm just testing different ways to condition them. once found i'll scale up to the right sizes. Now my question is Does it matter how big your water tank is? or is there a minimum number of pipes to make it work correctly? or for that matter a minimum lenght?
The only way to Validate is to Replicate!
maxc
http://www.youtube.com/user/Jdub6d9
About 5 years ago I had a green arc going in a small moter like that.
Gheller J
Duranza:
The tank size doesnt matter as the leads go directly to d tubes.
No specifics for minimum pipes or lengths
Gh. J.
RunningBare
Re conditioning of tubes
Would it be possible to speed up conditioning by first electrolyzing them, then remove to an oven for rapid drying before the oxygen has time to do damage?
