Stanley Meyer replication with low input power
Started by hartiberlin, August 18, 2007, 04:39:57 PM
leeroyjenkinsii
I was just looking at Stan Meyer's explanation of one of his cells on YouTube and it got me to thinking.  He was discussing how a laser could be used to keep the oxygen and hydrogen atoms in an excited state so they could not recombine to form water.  This, he said, would give off extreme heat/energy.  This is what is done to gases to form plasma.  They are subjected to high energy fields, i.e. microwaves, lasers, radio waves so the electrons cannot naturally stay within the atoms.   Examples of this are the laser induced plasma channel and microwave plasma experiments on YouTube.
I think another example of what Stan Meyers is talking about is the Kanzius affect.  So the radio waves cause the water to split with the salt serving as a catalyst.  Once the water is turned into HHO and it is lit, it starts to attempt to combine back into water.  This would usually lead to a small explosion and the recreation of water but that does not happen in the Kanzius experiments.  Instead as the HHO attempts to form H2O it is unable to do this because the radio waves are exciting the gas and it is staying in a plasma state giving off 3000 degrees heat as Stan Meyer's said.
Is anyone working on a Kanzius recreation?
Spewing
Quote from: tao on September 17, 2007, 09:13:27 PM
Quote from: RunningBare on September 17, 2007, 06:46:28 PM
The output from a modern line output transformer is DC due to the fact it has a built in diode/capacitor voltage multiplier.
Quote from: TheNOP on September 17, 2007, 06:18:41 PM
was it DC ?
if not, the plates were constantly changing polarity and  only shaking the molecules
the task is not "breaking the dielectric barrier of water".
it is to apply a force to dissociate its molecules.
imo. at 10KV the distance between plates would need to be revised.
about the schematic, i suggest to replace the lamp by a battery.  ;)
DC isn't what we want to use, we only want to use IMPULSES.
Ponder this profound example:
If you take a 1:1 transformer and put a 12V battery on the primary side of the transformer, and on the secondary side you place a bridge rectifier and a capacitor.
Now, on the primary side in series with the 12V battery and the primary of the transformer you place a simple switching device like a transistor or FETs.
Now, the start conditions are as such: The battery is at 12V, and the capacitor on the secondary is at 12V...
Having 12V on both sides of a transformer means no current flow, so if you were to apply a simple square wave to the primary of the transformer using the 12V from the battery, there is NO current flow in the secondary because the capacitor on the secondary is at 12V, UNTIL that magnetic field that was built up in the transformer collapses...
Now you have a VOLTAGE pulse (pure EMF) of anywhere from 50V-1000V, and since the primary is now an OPEN circuit, this voltage pulse moves onto the secondary, but now, since the voltage is greater than 12V, this voltage DOES ADD to what is stored in the capacitor. Capacitors are the best conversion devices for these TYPES of pure EMF pulses...
That is just one example...
So, we aren't using DC, that is Direct CURRENT, we are using improvised PULSED DC, such that we all but eliminate ALL CURRENT FLOW...
So, you CAN apply 10KV+ to stainless steel plates that are in water, and the distance wouldn't have to be revised, because we aren't ADDING electrons to the plates, only this VOLTAGE FIELD...
This is what Bedini calls his 'radiant energy'........
well put!
this picture is something that lerks in the back of me head...
esaruoho
Tesla Impulse Technology based patent for creating Ozone by using "pulsed DC"
http://keelynet.com/tesla/00568177.pdf
now we are finally getting to the root of things, impulse tech. gerry vassilatos has written quite a bit about these fast interruptions of DC, pulsing them to a specific frequency, and what Tesla discovered he was able to accomplish.
funny tho, everytime we go back to tesla ;)
RunningBare
I need a judgment call folks, I've just made a 15 second video of another conditioning process, but that seems like a lot of bubbles for less than a watt input, 13 volts 50ma, thats what the meter showed, but I'd say it was more like 60ma.
http://www.youtube.com/watch?v=pbf0SSgrJV0
One day I'll get the bloody seal on this water tube to do a proper test!
Gheller J
Runningbare>>>
thats 0.78 watts max >>>> not bad at all  >>>>  ure reachin there mate!
Check d followin vid of hydrocars @ 20.9 watts!!  >>>> 11V 1.9 Amps   >>>>and still reducing!
He seems 2 have done it!
http://www.youtube.com/watch?v=GXzTtm-QwtI
Way 2 go mate! one winner >>> few more 2 come!
Gh. J.
