Stanley Meyer replication with low input power
Started by hartiberlin, August 18, 2007, 04:39:57 PM
RunningBare
Keep your hair on!  :D
http://en.wikipedia.org/wiki/Bifilar_coil
Some bifilars have adjacent coils in which the convolutions are arranged so that the potential difference is magnified (i.e., the current flows in same parallel direction). The magnetic field created by one winding is multiplied with that created by the other, resulting in a greater net magnetic field.
Quote from: HissyfitNihilism on September 27, 2007, 02:28:45 AM
A superb example of idiotic non-science tripe.  Just the kind of pure idiot fantasy Ashtweth loves!
Bifilar winding of a coil does not increase its magnetic field energy storage.  It increases its parasitic capacitance, thus lowering its self-resonant frequency.  Whoever drew this picture and wrote these words has misinterpreted Tesla and made him look foolish.
dutchy1966
@ Runningbare,
Have you already considered using an EEC (Electron extraction circuit) as that seems to up the efficiency further? ( the extraction will  stop atoms from recombining after they have been separated already).
regards
Robert
RunningBare
@dutchy
Not yet, I'm still trying to get the best out of the circuit, and as you have seen my tubes are pitiful to say the least, I will try EEC later, but I do not have whopping great capacitors, best I have is a few 11000mfd types.
Quote from: dutchy1966 on September 27, 2007, 10:12:23 AM
@ Runningbare,
regards
Robert
saintpoida
thanks runningbare and dutchy found it
If anyone else in australia and needs a part number IRFP240
i was told its a replacement part for BUZ350. It has same voltage/amp
specs so it should do the trick.
3 more questions
1.) If i wanted to wire in a light to tell me power is on would i just wire it in parallel with the
power switch? And would it need a resisitor or anything as well? (LED)
2.) If i wanted to wire in lights to flicker with the pulse where  would i wire those in?
3.) Finally the dum question! On the diagram on page 10 of d14 where it shows the wiring to
the knobs, switches, inputs/outputs etc i wire it up how i see there dont i?
What i mean is the ammeter for example has a cable going from its right side to 2 places
as does the mosfet, so i just wanted to check this is definately the correct way of doing this?
Thanks again guys! almost there
Oh and is a 7amp fuse ok instead of 6? i assume its ok
Spewing
Quote from: HissyfitNihilism on September 27, 2007, 07:12:58 PM
Quote from: RunningBare on September 27, 2007, 10:07:46 AM
Yes...it is multiplied by two, the number of windings.  But it is the same energy storage as a single coil with an equal number of total windings.  The idea that bifilar winding gives some great multiple of the inductive energy storage over a single-filar coil of same total turns is simply wrong and can easily be disproven by simply doing the experiment.  All wiki means is that the coils will aid each other if in phase (i.e. 1+1=2x) and oppose each other if anti-phase (i.e. 1-1=0x).  The idea that hundreds of thousands of times energy storage is magically achieved by bifilar winding is just pure rubbish.
the transformer not under any kind of load should put out well over a thousand volts, the coils reduce current on both sides to the cell.. when the transformer starts to pulse the wfc threw the chokes the cell gets energized at that time, the cell is taking on a charge, during the off pulse of the primary side of the transformer the chokes is emitting back emf to the transformer witch is in parallel with both of the chokes "at that given time". by the time the 3rd pulse arrives the chokes work with the transformer in a series fashion, this multiplies the voltage across the cell.
each time the cell is step charged the voltage across the cell increases, each time the cell increases in voltage the output from the transformer to the chokes is increased, and stronger emf is emitted. once the cell reaches its peak the transfromer is now putting out over its maximum thousand volt rating because of the series positioning of the chokes. the second side of the circuit is now resonating, meaning the circuit, not the water fuel cell.
each time the cell takes on a step charge the amount of amps in pulses applied to the primary side of the coil drops, when the cell becomes completely charged hardly any amps is consumed from the primary side of the transformer.
this is not overunity, it is just a resonating "circuit" that works.
