Stanley Meyer replication with low input power
Started by hartiberlin, August 18, 2007, 04:39:57 PM
HeairBear
the schematic is in this pdf...     http://aquapulser.com/docs/independent.pdf
I have never seen a wave form of Stan's yet. I hear and see many people show their wave form but never the original to compare to.
When I hear of Shoedinger's Cat, I reach for my gun. - Stephen Hawking
capacitor70
How many people successfully replicated Mayer's cell ?
I have done lot of R & D on Mayer's bifillar coil, but not a single coil worked for me. Ravi says he is using step up transformer 200:600 ratio for his cell.
Dave lowton video shows without coils nearly same output can be obtained. bifillar coil is not much important.
What I see in my research is conditioning of tube is very important I have taken multiple trials of conditioning at high current, low current and Dave lawton steps for conditioning, After conditioning of tubes output of gas goes very high and current requirement goes low. But pulsating input is required to get best results after conditioning....
Pictures
1. Conditioning at high current (after long time blocking problem occurs, easily breaks, powder like coating)
2. Conditioning using Dave Lawton Steps. (Hard non conductive uniform coating)
newbie123
I have a very even coating in one of my experimental tube cells, and the coating is so thick it pretty much fills the whole 1.5mm gap..  I got this by using low current (minimal bubbles), with straight DC electrolysis, for 3-5 hours .. Then let dry, or use a blow dryer, then repeat .. After about 2 weeks the coating is very thick.      And it looks like a crystal formation (symmetrical) at the bottom side of the cell.
Not sure if that will lead to the same results as Lawton/Ravi but it worked well for making a thick, tough, oxide coating.
HeairBear, Thanks.
Until you can measure it, arguing about something can be many things.. But science is not one of them.
newbie123
ashtweth_nihilisti
Hi current is not recommended, the coat wont bond, have you read Ravzz new doc? Also can you do a gas flow test now, and then add the NEW V.I.C and note the difference?
You might need to start conditioning again.
Ash
Quote from: capacitor70 on August 18, 2008, 10:20:58 PM
Pictures
?If you create your own electricity, heating and water systems, you create your own politics. Maybe that?s what they?re afraid of.? ?? Michael Reynolds
http://www.panacea-bocaf.org
http://www.panaceauniversity.org
http://www.geocities.com/glorybangla/cqtes.htm
