Stanley Meyer replication with low input power
Started by hartiberlin, August 18, 2007, 04:39:57 PM
ashtweth_nihilisti
Guys i know in our modern world patience is like being on another planet ::) :)
I know how frustrated we can get, and how anxious we all are to finally get some results, think of your self on that day 8)
With this in mind, we have to be patient, think of the pay off at the end of it huh?
All are doing well.
Ash
?If you create your own electricity, heating and water systems, you create your own politics. Maybe that?s what they?re afraid of.? ?? Michael Reynolds
http://www.panacea-bocaf.org
http://www.panaceauniversity.org
http://www.geocities.com/glorybangla/cqtes.htm
kewlhead
Quote from: HeairBear on August 25, 2008, 05:48:52 AM
Interesting, reversing polarity is weird. If done slowly by hand, you get gas bubbles and those strange current effects. Using AC @ 50-60hz does nothing but heat the water. Like a Davey Bell Heater. Ash is correct when saying the reversed polarity will ruin the coating process. BUT... Stan talks about a particle oscillation( I have no clue how he could know this) that happens between the plates. This oscillation is dependent on the input frequency matching the space between the plates/tubes. What frequency has a 1mm wavelength? Or maybe quarter or half wavelength?
HariBear wuld you have any idea wat that thang is he is holding? I use to think it was a pre-treatment process or like his older EPG  thing but there doesnt seem to be any power connections on that but of tubing..... wat is that thing?
HeairBear
That there is the heater unit. That's all I really know. I'm sure it connects somehow inside like a plug for the power.
When I hear of Shoedinger's Cat, I reach for my gun. - Stephen Hawking
Jamie
He heated the water before the injectors? I always thought that Stan thought heat was not very efficient. Huh.
A bit about locking onto resonance from Zero Fossil Fuels:
http://www.youtube.com/watch?v=vKjUzsNj8NM&feature=related
Blue is the waveform into are VIC transformer in the picture below.
Red is the waveform out of the transformer.
My question is, are only the negative voltage spikes being used? The positive spikes don't occur (on VIC side) because the blocking diode won't allow it, therefore the positive EMF drops across the wire connected to the PWM instead. Making the square wave kinda trail off on the PWM side, correct? Isn't this a waste? or do I have something confused. Note: I do not have an oscillascope. This is theory, I haven't actually seen this.
professor
Interesting
Would like to get some phosphoric Acid which is quite dangerous as it can be absorbed through your skin and destroys your bone tissues.
I used to have some  allbright which was an Industrial Cleaner they used on stainless tanker cars it contained 60% phosphoric and some other nasty stuff.
I have not been able to obtain any Phosphates locally so I looked to see what I could find in my Household that contained Phosphor
Found some Plantfood that contained amongst other ingredients 20% phosphoric acid
My Idea was also to speed up the process of coating the electrodes.Anodizing Stainless unlike aluminum is difficult or not possible .
Using this highly conductive fertilizer for 1 Hour at 12VDC  it produced  a Black coating on the Cathode.I then mixed some Bird Gravel from my Parrot which contains Oystershells and a few other things and this produced a good coating giving me anywhere from 8 Megohms up.
The Coating is fairly hard and very adhesive.
I thought of using" Waterglas" Na2 O.XSiO2 a substance that was available everywhere in the 60's and 70's  but no one has even  heard about it when you go and shop for it now. It was used  as a preservative and was very cheap and as a clear liquid it hardened like glass. I think it would make an excellent insulator for our purposes
Professor
quote author=Lazaris2005 link=topic=3079.msg122571#msg122571 date=1219277575]
In this link
http://www.sciencedaily.com/releases/2008/07/080731143345.htm
we can see that scientists "have developed an unprecedented process that will allow the sun's energy to be used to split water into hydrogen and oxygen..."
"The key component in Nocera and Kanan's new process is a new catalyst that produces oxygen gas from water; another catalyst produces valuable hydrogen gas. The new catalyst consists of cobalt metal, phosphate and an electrode, placed in water."
Just an Idea :
Would phosphate speed up the tube conditioning ?
Search this forum the word phosphate and you can see sources of phosphate like SODIUM PHOSPHATE and monoammonium phosphate.
If someone can test, please share the results. I was not able to gather all the material for assemble a cell yet.
Greetings from Brazil an thank you all for sharing such knowledge. ;)
[/quote]
