Stanley Meyer replication with low input power
Started by hartiberlin, August 18, 2007, 04:39:57 PM
sparks
    Let's make the impossible assumption that your engine draws in air (just like a heat pump draws in low pressure heat saturated vapor).  and compresses it.  Now you have the equivalent of the heat pump compressing the low pressure heat saturated vapor into a smaller volume in order to raise the temperature in the condensor.  This is done to radiate the heat taken in at the evaporator.   So the oxygen in the air is at a higher temperature than when it was uncompressed. Inject fuel.  Your hydrogen sees oxygen at 15 atmospheres of pressure and ignites.  This is an exothermic reaction. Our goal here is to increase the pressure in the combustion chamber not heat up a building.  The fairly inert gas nitrogen  is the receiver of the heat released in the oxidation of hydrogen.  It reacts by expanding.   You will notice that rocket engines don't use hydrocarbons.  They could but they don't.  There is no need to transport hydrogen into the rocket engine using hydrogen bound to carbon.  The hydrogen is bound covalently to carbon.  In order to get the hydrogen from carbon you have to break these bonds.  This is endothermic.  Where does the energy come from to break these bonds?
   For every mole of water you split you get 2moles of hydrogen atoms and one mole of oxygen atoms.  We dont need the oxygen gas we have some in the atmosphere already split off hydrogen for us.  What to do with the oxygen.  Well lets expose the whole mess to ionizing radiation like uv light.  The oxygen now forms 03.  O3 contacts water recycled from exhaust.  It quickly breaks down to hydrogen peroxide.  Inject this into the cylinder through a silver grid or plated injector.  The hydrogen peroxide now goes exothermic forming water real fast.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
forest
Tesla once worried about burning atmospheric nitrogen using his coils at 12 million volts.Maybe combusting air is just that with lower voltage but higher pressure inside combustion chamber.
sparks
  Nature in all her wisdom knows that it will ruin itself if it takes nitrogen and oxygen and combine it.  Therefore it maintains a temperature and pressure that does not allow for this to happen.  It takes radiant energy like UV and IR and elegantly captures this energy in various chemical bonds.  One of these chemical bonds it stores this energy input in is oxygen.  In an engine we take this chemical potential energy and convert it into kinetic energy of the engine.  Pounds of oxygen go through an engine a minute.  But we are lead to believe a teacup of a majical substance called gasoline is what is supplying the chemical energy to move the car.
Think Legacy
Spread the Love
canufi
Quote from: microcontroller on June 03, 2012, 04:54:23 PM
So at this point it doesn't even matter where the extra energy is comming from.
Huh?  Yes it does matter. If the energy is coming from the sun, it's not Over unity, it's f**king sun energy.
The amount of idiocy on these forums is almost enough to drive a person permanently away from the forums...
Why argue with fools? Why suffer fools?
If the energy is coming from Stars, it once again is not over unity - it's star energy.
canufi
Quote from: forest on June 03, 2012, 04:03:53 PM
canufi
You are wrong about radiant energy because you don't see something which should be obvious. Something which was a mystery for centuries. You said that radiant energy is coming from our sun and it's true but only partially. Sun is the closest star but most of radiant energy comes from cosmic background , from all stars in universe.
I'm not wrong, you're pulling this radiant energy stuff out of your rectum to try and fill in the gaps, just like christians say "The energy came from God".
What evidence or proof do you have that Stan's device is pulling energy from Stars far away? Why not just admit it - Stan's device is not pulling energy from stars, it's pulling energy from Aliens and UFOs in outer space that are secretly transmitting energy from their UFO spaceships at certain radiant frequencies!!!111!!!1
No, really - God did it.  Stan's device works because of Jesus Christ the Lord all mighty.  Jesus sends energy to Stan's water capacitor only at certain frequencies, and the pipes resonate acoustically to Jesus' urination pipe on his groin.
Why argue with fools? why suffer fools?
