Stanley Meyer replication with low input power
Started by hartiberlin, August 18, 2007, 04:39:57 PM
lltfdaniel1
Hmm Interesting, hope he keeps going with the tests and all.
As for people on to ravi,
I Have a suggestion, get a tracking web cam, and make it online,and people could take screen shots from webcam you know and record, it will be very interesting,
yippe to big brother,
although business man see money as life in millions in selling oil,
and money buys oil,
and oil shortens the natual food production,
and if a carrot gets to a cost of 1 million,
you surely get poor to bankrupt very soon , unless you order alot of food at 2007.
and that will happen.
well you could eat paper.
its fear really.
68:16 But by this, THEIR KNOWLEDGE (science - 1 Tim. 5:20), THEY PERISH, and by this also its power consumes them.
twh 1:1 Thousands of earth years ago,far away,in this galaxy,on the morning star(venus),the Lord Guardian Of Divinity,King ruler and Guardian of the Universe,put down a revolution led by Lucifer(Iblis)
bolt
Just a thought but each tube maybe much better fired from 8 different controllers. Yes this is loads of work but assuming each tube is an end fed dipole waveguide then they may all require a slightly different frequency and/or sequence of firing.  Maybe like 1,8,4,3,6,5,7,2 is standard V8 timing LOL
Well you never know the collapse of each field between the tubes may greatly enhance the system. I noticed some want to leave out the diode in the output circuit. Im not sure thats a good idea for a start the way it works in theory at least as pulses across of the choke see the voltage increasing rapidly, the diode syphones this off and is held on the tubes capitance. At each cycle coming from the controlling the leading edge of the back EMF is tapped off by the diode which prevents the voltage from collapsing thus producing the very high tube voltages otherwise unlikely to get higher then the PSU supply at 12 volts. I notice some designs have a bleed resistor across the tube to help slam down the voltage after but i would not thought this would make a practical difference.  Once the current of the system is low and fully tweaked the only other way to get more performance i can see is to either build bigger tubes or get the voltage up on the tubes. This means using perhaps switch mode power supply inductors with transformer taps and really get that 12 volt chop cranked up to 1000+ volts to the tubes. I think the pratical limitation is when the thing starts literally arcing across the tubes which is not good but then we found the breakdown voltage of the system if one gets this high.
Anyway, perhaps see first if building two controllers and running 4 * 4 is better then one controller and adjusting each set of 4 independently. If there is no noticable gain with 2 controllers it may not be worth the hassle of running eight.
Just ideas..........
ashtweth_nihilisti
antomarki Ravi followed D14, the the plans are there, we will be publishing ours here too
?If you create your own electricity, heating and water systems, you create your own politics. Maybe that?s what they?re afraid of.? ?? Michael Reynolds
http://www.panacea-bocaf.org
http://www.panaceauniversity.org
http://www.geocities.com/glorybangla/cqtes.htm
keithturtle
Yeah, mramos, but there be nuthin' like a good mystery <grin>
Turtle
Soli Deo Gloria
ashtweth_nihilisti
mramos the magic is not in what you stated, you don't have a unit working like dave lawton and Ravi, i have spoken to Dave lawton and Ravi, i am in a position to know.
Thats a very large generalization i care not to refute.
You have nothing working or you would get a visit, i advise the skeptics and oil men, to stay out of this, and for genuine replicators to ASK, and or contribute. Replicate.
