Did someone tried to replicate a Hendershot Generator ???
Started by robbyd, August 19, 2007, 10:33:56 AM
Skysabre
Dieter,
I thank you for the lead. I will try that out too, after a few more experiments on the Hendershot unit.
MenofFather,
Your ideas will be most welcome. It doesn't matter if there is no guarantee. If it can be done, and is affordable, then I will try it out.
Thanks to this community. Let us remember Thomas Edison's persistence!
MenofFather
Quote from: Skysabre on April 18, 2014, 10:51:25 AM
MenofFather,
Transformer is 3-5 kilowats. If they heat up, need it disasamble, and all paint with emal, lack and then maybe reglue, not use screw, then it makes it heat up, you can use string tubes, put in it bolts and after bolt put dialectric, to not conect diferent sides. First wound primary like in normal transformer. Then shield of aluminum, How I understand, shield is like shorted turn. Then secondary, then again shield of aliuminum foil or tape like shorted turn. In one transformer is two shields and in other. Capasitor must be in resonance. Then you find resonance it makes vibraite wery loud, then you find, let say, not 50 herc resonance but 150 herc resonance, then it vibrate not that laud. You need find 50 herc resonance, if socket is 50 herc. Here video, there he explaining everything in russian language. [size=78%]https://www.youtube.com/watch?v=Uu2Rbjr80RI&feature=share[/size]
Good lock!
dieter
Skysabre,
I thought I got to let you know, Gyulasun just told me there may have been measurement errors in the project I linked to. But as far as I do know, there is nonetheless a certain potential in using caps to "go out of phase"  in order to draw "free" energy (with the power bill in mind)  8) .
MenofFather,
looks pretty scary, this circuit. But also rather simple. Do you plan to build one?
gyulasun
Quote from: dieter on April 19, 2014, 09:23:51 PM
Hello Dieter,
It is not just uncertainty that "there may have been measurement errors in the project you linked to", it is sure there was errors, gotoluc clearly described them, he did not simply accept the "armchair explanations".
Gotoluc just addressed this again to member Vince here: http://www.overunity.com/14443/quantum-energy-generator-qeg-open-sourced-by-hopegirl/msg398657/#msg398657
Of course you have got the full right to question anything and convince yourself by doing many tests yourself, this is the best approach towards reality and this approach is okay to me, no problem,  all I can do is to wish you good luck.
Gyula
MenofFather
MenofFather,
I thinking about this divice, maybe in smallest version and on ferite and on hight frenquency. Because original version is very much cost and maybe dificult disasamle core and paint it to it not makes warm...
