Formular to calculate energy per liter of HHO gas
Started by hartiberlin, August 21, 2007, 02:18:30 PM
magnetrecharge
Well I am sorry to have be the one to throw a wrench in but it's true. In all of meyers videos he lucky to be producing 1LPM. I have been expiermenting with a mock up cell so I have pretty good idea visually.
Quite frankly I think they are all full of shit and good at magic. I mean what the hell? David blain can walk on water and shit. I will have you know I work with the best and I have 200 HP car dyno at my disposal as well a one million dollars worth of research equipment so if anyone really wants to show me they can. There is just one catch. you won't be fooling me becuase I will hook up every piece of equipment including the gas samplers. In all the videos on youtube there is one flow meter and it's telling the truth. 40 amps for 2 LPM.
No one has proven anything and those that claim crazy numbers can't be contacted. Hmmmm, what would that be? This is bull shit but have fun.
Creativity
Quote from: magnetrecharge on April 23, 2008, 08:25:10 PM
Did any of you run the calculations to run a ICE on hydrogen?  You guy's are just to funny.
The amount of oxyhydrogen needed to run an internal combustion engine is spectacular. Idling a small engine (e.g. 5hp) would require 500-1000 LPH (liters per hour), while idling a car engine would probably consume about 3000LPH of oxyhydrogen. Driving down the highway would probably consume 20000-30000 LPH of oxyhydrogen. Have fun.
actually i did calculations right here and i agree with u that it needs a huge amounts of HHo to run a car:
http://www.overunity.com/index.php/topic,4424.0.html
I gave also good arguments on HHO addition in other theads.So when somone says he is running his car on HHO only i just smile.Anyhow HHO addition can shift the lean burning limit of existing fuel mixture,so it makes some space for engine tuning to boost mpg,BUT u actually have to adjust your engine ,otherwise i see it difficult to work as a pure add-on system.
Blues it through your outstanding life,leaving more than just footsteps behind (1999 B-stok by me).
By being intensively responsive to what others say,i do run a risk: I open myself up to the opinions of others.i will,at times, have a great understanding for their opinion.Sometimes,i will even change my own opinion because i realize that the other person is right.This "risk" i do not run if i am unresponsive to what others say.
ramset
MAGNA  nice to have you here  your obviosly interested in the truth   so am I  and others here  at the top of this Forum on left side is a board click on Zero point energy  a fellow wrote an article  yesterday on this and has links to the new devices BIG production  people that should talk to you and want to[ I hope]   Chet PS heres the link also another article on GEET above this one   jibbguy/ http://www.opednews.com
Thanks Grandma
magnetrecharge
Well let's just say I have an open mind. I am not a nay sayer but no one has provided me with anything but claims.
I will say this. I try and stick to the law's.  That said I have observed strange things. I have a very large iron core choke
that came out of a frequency drive system. It's weighs about 15 pounds!I am using a 150 MM h2 flow meter. Without the choke the cell is producing about 40mm. With the choke installed it climbs to 70. In either case there was a definite increase with pulsed frequency.  I can say without a doubt that there is something going on with PWM. I am only using a simple circuit with a signal generator. I am current limited  to 2 amps. This is what is puzzling. On the scope  I'm reading upwards of 80 volt PP spikes on the scope. Note that I wm working in the 20 volt range. It seems to produce the best in the 15 to 50 KH range. Note that I am not using the fancy Lawton circuit yet.
So here is my report and itst 100% unbiased accurate.
I will try and retest today.
No pulse at 2 amps current limited.  20 MM HHO gas.
Pulse          "                             "   30 MM  "         "
Pulse with large choke in series
with the positive side.                     70 MM  "         "
ramset
Magna your the guy thats been missing here someone to verify the results LanMasterd Feynman Z monkey and others are simplifying the PWM to a computer device  you should look in  alot of hard work already done by very skilled and determined men   Chet
Thanks Grandma
