2 Watts from an old 2N3055 as a solarcell ?
Started by hartiberlin, June 04, 2005, 01:34:25 PM
DeltaMan
Well ,
things did Not go as I was expecting . Current seems to be Very Low even in Sunny days .
One cable was soldered to the Base of the transistor and the other on the Collector or the Emmiter (I am Not sure ) . After that , both were connected in series .
When exposed to the Sun , I could measure about 0,8 Volts . When the sunlight was enhanced with a Lense and focused on one of them , voltage seemed to rise up to 1 Volt .
The next step was to connect a Tiny DC Motor but when I did that , there was an Enormous drop in voltage (close to Zero) and the motor would Not move of course . That indicated that I didn't have any Wattage there .
According to the power they had and the cost of them plus the cost of the lenses plus the man hours to fit everything together , I came to a conlusion that a Typical Solar Cell of the market would be way better .
Just my two cents .
DM
triffid
I had heard about this about 5 years back.I took a clear LED and focused some sunlight on it and got a couple of volts.Triffid
lon92
khabe
About magnifying glass.
How many energy you can get direct from sun focused through 5" magnifying glass ??? Relatively a lot of :o
http://www.coolschool.ca/lor/PH11/unit8/U08L04/conv1.gif
And then what about 2w you can get when using  2n3055  >:(
It was somewhere in 1966 we tried with guys to "get electricity" with cut off tops transistors  ... no lenses of course ::)
greetings,
khabe
Paul-R
Quote from: triffid on November 10, 2008, 01:01:36 PM
I had heard about this about 5 years back.I took a clear LED and focused some sunlight on it and got a couple of volts...
...and how many amps (or mA )?
Paul.
