Parts list d14
Started by saintpoida, August 28, 2007, 06:22:16 AM
saintpoida
keithturtle
Boiled in acid.   The process uses acid to remove any traces of Fe in the surface of yer pipes / plates.  Then when ye run 'em they don't turn brown.
Big in the food industry so SS doesn't contaminate food with traces of rust.
Iron cain'toxidise if it ain't there.
I use a one-step process and a chemical called citrisurf.
http://www.stellarsolutions.net/2050data.htm
SOak 11 min at 80-'C then rinse with distilled water.  Handle plates with gloved hands forever thereafter [no skin oils]
Turtle
Soli Deo Gloria
saintpoida
oh ok so thats similar to the idea of annealing?
Pete
keithturtle
not really.  Annealing is a heat process, where passivationg uses chemical action to git rid of free Fe.  The heat jes accellerates it.  It would work cold, jes slower.
Annealing helps when, after "working" a piece, residual magnetic fields are eliminated.
Fe (free iron) is what turns the water brown and precipitates to the bottom.
Keith
Soli Deo Gloria
