Kwh meter as homopolar generator
Started by alex681219, August 31, 2007, 06:27:14 PM
kallstrom_74
Quote from: alex681219 on September 11, 2007, 02:58:52 PM
talking about turbines see http://www.youtube.com/watch?v=teZgQannjK0&mode=related&search=
http://www.youtube.com/watch?v=q9flSPAdOLk&mode=related&search=
it looks really nice and could work..i can build the "helix sails"..but fixing the gearing and hook it into a generator..that i cant figure out how to build that
alex681219
make a shaft pvc extenssion and atach the sails on it, or atach a twin flyweel to the alternator(generator) with a belt.
kallstrom_74
okey! but how can i get it to 240 volts?...drive wirer from the generators to a "240 v converter" or something?
any good generators that would be suitible?
just a idea!? from the shaft would it be possible to put a cogweel and a shain (like gears on i bike) to make more turns before it drives the generator?
alex681219
If you want all the energy available to conect all the things you conect in your home, you will neen a BIG generator$$$.But the challenge is use more neurons and less money.
The solution is a huge battery bank that store the energy generated by more than one solution. the key is mix wind, magnetic, hydogen and all you can develop to create energy even static.
This is the reason why I-m here. Until know the bedini and newman machines seems to me a good solution, works with dead batteries 4 start(cheap), maybe mixing cavitation heaters with magnets in the holes...and a lot wing turbines in the roof...the ideas are raining.
If you dont know the fundamentals of this things ...you can to learn faster...reading...warching videos y vgoogle and you tube (hundreds). peswiki.om is a good start point!! the limit of your mind is your self.
wind turbine home made
http://www.youtube.com/watch?v=FN2Fkf8LNVs
http://www.youtube.com/watch?v=be-vZ45hN9U
click in alex681219 and see my favorites
