Possible major break through, LPSS
Started by Butch LaFonte, June 06, 2005, 02:33:27 AM
Butch LaFonte
It's 1:00 am and I may be so sleepy I'm wrong on this, but I believe I have a major break through with a Pseudo Solid Stator design. Look at my drawing on my free web site until Sky can upload it to my paying web page.
The rotor is pulled to the turned magnet (second one down the role in drawing), then that magnet is turned inline with the first, the cycle keeps repeating till it gets to the end and stops (rotary version just keeps going around in same direction) Then is move back to start the cycle over. This can be tested at home with radio shack magnets and a piece of glass as a divider. Interesting thing, the magnets rotate to line up with the steel rotor with more force than it takes to rotate them back sideways after the rotor is slid back to the start. This elimates any rotor banging.
Butch
See at > http://butchlafonte.50megs.com
magpower
Hi Butch
I am really impressed with your work and going to test my mini version on LPSS. I am using the parts from small D.C motor as the rotor. I cut four rotors from the armature of the D.C motor. Does the arm have to be non-magnetic it looks like you are using metal on yours. Will post pics once I get things together.
On your LPSS you are rotating your magnetics 90 degrees and then back again. Would this not use up energy for each flip. And how would one do this easy. Looks hard to build.
Thks
Wayne
Wayne,
I think the LPSS is much harder to build
and it is vague, if it will work.
Go first with the LPSR and yes, you can use magnetic arms.
Post some pics, when you have any results.
Thanks.
Regards, Stefan.
prometheus_effect
Hi Stefan & Butch,
Have a look at my crude flux contour and you will see why the LPSS will not work. Rotor 1 will be strongly pulled back to it's mate rotor 2.? :(
Greg
Now its just engineering effort, time and money,
Prometheus_Effect
Greg,
but waht about the lower part of the rotor ?
There is still the force to go on !
ALso at the bumping of the rotors the kinetic energy is
huge and is transferred to the other rotor, so it should be able
to overcome the sticky spot.
Maybe some iron shielding plates at the top stator magnets
will help.
Regards, Stefan.
