magnet strengths to distance, and pole question.
Started by nirvana, September 04, 2007, 08:19:07 PM
nirvana
   hi members, i have a few questions regarding magnets.
  Does anyone basically know the strength differences in neo magnets, compared to the distance they are to each other when poles are opposed..
   e.g., a neo magnet with a 2cm squared surface area on the poles may take 25 kg to push the poles together, the imformation i am needing is if they are 1cm apart what would the amount of force be, and how the force increases as they get closer to each other.
   Another question is, if i have a magnet, say  a 5cm  long rectangle shape with the poles on each end, what happens to the poles if i place 20 of these magnets side by side.(Not pole to pole).
   Assuming these magnets are 5cm long with a 1cm by 1cm pole on each end, and placing 20 of these side by side would now be like a 5cm by 20cm by 1cm magnet, would the poles still be on the original  ends of the 5 cm height, or will they now change and be  on the opposite sides of the 20cm length.
Thanks.
Thaelin
Hi Nirvana:
   First thing you must realize is that it is going to be one heck of a fight getting them all side by side. Remember, like poles repel. I have some neo's half inch long and half inch diam and they will lift fourty pounds. I believe they are N36 grade.
thaelin
tropes
Quote from: nirvana on September 04, 2007, 08:19:07 PM
Good question nirvana. The neo magnet sellers seem to promote only the holding power but I'm sure they would have the numbers for pull and push strength at distances. I have not been able to find one but I would like to see a graph for both attraction and repulsion. Hopefully, a group member will be able to help.
Peter
gyulasun
