White powder Gold
Started by innovation_station, September 06, 2007, 11:17:36 PM
Prophmaji
All of this also supports the 'expanding earth theory'.** Yes. What does a person expect, but "from one ludicrious theory to another"? :P
http://www.nealadams.com/nmu.html
KISS
Some guy was watering his walnut trees with this "Ormus" and another guy was feeding it to his chicken... check it out.
http://www.subtleenergies.com/ormus/tw/giantnuts.htm
Gold in it's metallic form requires 2 or more gold atoms bound together sharing a covalent bond between the atoms.
White gold... Orbitally Rearranged Mono-atomic Elements ORME (Ormus) is a single gold atom that is not bound to another atom and does not share a covalent bond with another. Thus Mono-atomic. Does not exhibit metallic properties with standard metal detecting instruments.
Don't eat it. It don't do shit for you... if you think it does its all in your head... Ears ringing?... thats the body trying to get the shit out of your body before it does any real harm.
Wanna make some?.. heh.. Before you try it better study up... I recommend not trying. Fusion in a boat. hehehe. Try extracting minerals out of Morton Salt... that comes right out of The Great Salt Lake in Utah. If you don't mind the mercury scare you might enjoy the magnesium rush off it.
Have fun.
Prophmaji
Nice pile of convincing evidence and science you've brought to the table, here.
I say there's FAR too much evidence FOR it to dismiss it and walk away.
I also say that these things should be well studied before dropping them as 'shit'....because they skip beyond one's personal level of emotionally based comfort.
So I..like a sensible researcher..will continue researching.
And people like you..will continue to detract and call it 'bull'. Based on WHAT evidence do you call it bull?
When following all known methods and possibilities within the idea of scientific method and available data, even data collected and created by others-instead of personal developments..the numbers and stories are too good.
I mean, hell.. people with access to every kind of story, fact generation system and lie known to man, who have attempted to 'pull the wool over our eyes'  in every theater available, be it science, politics, religion, etc...even they cannot create a story this solid, that is this 'leading edge', and also goes deeply into areas of science that are NOT YET UNDERSTOOD, but STILL meet the criteria for solid evidence. And, most specifically, I'm speaking about one generating their own research and their own logical considerations..under that method of research, heck, the story HAS to fall apart somewhere..there HAS to be SOME, even ONE single point where this story falls apart..SOMEWHERE, one single point, please!!!
But..it does not.
If you are frightened of where this may lead, please go hide form the bogeyman. I see none here. :)
I am advising EXTREME caution but I have yet to see a single point showing that this is 'crap' of any kind.
I've yet to see even one single point that does not fit, out of many logical conclusions and facts I have pulled out of many other sciences..MYSELF. Not stuff someone has fed me, not junk science and research that someone else has fed me, but ... long, complex fact searching and logical deduction.
If I can wander down 3-4 other paths in science -and I DO mean leading edge science, where the work is barely emerging...and this stuff fits it to perfection, in terms of the science behind it, and allows one to come to working, factual conclusions in other cutting edge new sciences..and come to NEW understandings that FIT PERFECTLY...well..then it doesn't seem like too much of a bullshit story now, does it??
Everything agrees. No cracks in the scientific armour yet. In over two years of HEAVY research. Not one single misstep yet, of ANY kind.   And that's the most impressive point of all.
So the Great salty lake has MERCURY in it, now..does it?
THANKS. I never knew that. One more FACT that fits.
You see... the story goes...to make the 'philosopher's stone', you need a electrolytic-like slurry that contains the gold, ie, some "Mercuric Sulfate (II), clean distilled water and highly dissolved levels of gold..and then..let this stew for about 30-40 days at about 120-90 degrees F..and then the conversion takes place. As I stated earlier in the thread. Mercuric Sulfate (II) provides the energetic reaction (a catalytic pressured state) to strip the gold structure down to it's individual atoms. http://www.bibliotecapleyades.net/esp_ciencia_lapidus1.htm
So..the Great Salt Lake and the Dead Sea are the PERFECT conditions to create the monatomic 'salt of gold', so to speak.What the White gold is supposed to be..is..oxidized platinum metals groups (specifically gold, in this case).... that have been torn down by a catalytic reaction, over time, JUST LIKE Rhodium does..if left to it's own devices..if plated on something....too thin.*** Rhodium does this on it's own, which is why Hudson says it is the least common of the platinum metals group....and is the MOST common as a 'oxide', or ceramic montaomic element version of Rhodium. He says gold is the most difficult to convert, due to there being only one stable isotope of gold. The bonds are very strong. Basically.. you are doing something very much like 'sulfating a battery'..but using dissolved platinum metals group in the electrolyte. (dissolved salts of the platinum metals group, just like in the oceans...hhmmmm?..but we don't know how to 'get it out', they say?)
THANKS..for the stunningly perfect data to help add to the pile of evidence!!!! :)
*** As for the Rhodium plating issue concerning 'self oxidation', and all 'directions' it indicates, in terms of Hudson, etc, being true..that is something I discovered ON MY OWN, and there was not the slightest indication from anyone, in any texts connected to any of this white gold stuff-whatsoever, as to why Rhodium is the least represented of the platinum metals group, and the most common in Hudson's monatomic work.
A question, then comes up: How does this relate to the guys who are creating HHO gas..but have to build up an OXIDE LAYER on their stainless tubes..in order to achieve the vaunted efficiency? No one knows yet why the oxide layer is critical, but they know it has to be done, in order to achieve the effect (high efficency) they are looking for, the stripping of the oxygen from the hydrogen (or the hydrogen from the oxygen, whatever). Note that ceramics are being used in the latest experimental versions of fuel cells. Another nail in the coffin of 'disbelief'? We shall see...it is another point that is entirely anomalous that can very likely 'fit into' this puzzle. It needs to be researched. I will remember it,and when the time comes..and the required point rears it's head to provide perfect correlation, I'll be there, waiting to fit this piece into the puzzle, if indeed it fits. At this point, it shows every sign of supporting the evidence. Just like every point in science and human knowledge I've researched so far.
And we will continue to look.....with eyes wide open.
IronHead
Amen!
Nicely put together "Prophmaji
Tink
Healers and goldenashpowder:
http://video.google.com/videoplay?docid=-2173642525917926602
This video is about alternative healers and I have to warn the faint of heart that in the beginning their are some boobies in sight ( I am still not blind thank god) and I ask you to close your eyes when they come in sight.
The goldenashpowder starts at about 54 minutes.
Maybe you find this movie boring, I thought it was okay.
Synergy is the key to free energy.
