Magneto Turbine
Started by Fresh, September 11, 2007, 01:05:02 PM
Fresh
Yeah Smoky,
no doult. But Here are a few other designs which may work better.
Try these.
The first has two positive tris' for the spinner, and positive / negative outter array (stator).
The second is a design using a single four sided ring, with a single pole representing the inner most side of that ring. In this model, the spinner is fitted with tris' close to the stator, with lead caps at the corner tips of each tri.
The lead acts as an insillator, working to keep the magnetic interferance constrained.
sm0ky2
now if i could just figure out how to make a unipole magnet, that might work...
hansvonlieven
Easy Smokey, all you have to do is wrap some magnetic shielding around one pole. That is according to some here.  :-)
Hans von Lieven
FreeEnergy
Quote from: Fresh on September 12, 2007, 08:53:57 PM
The whole device should be concealed within some material which has a shielding property to it that specifically blocks magnetic waves, such as lead, which may be dangerous as well.
lead blocks magnetic waves/fields? can anybody confirm this for me? because this would help one of my projects a whole lot.
gyulasun
Quote from: FreeEnergy on September 17, 2007, 06:11:33 AM
Hi,
Short answer is:  lead  does not block magnetic fields any better than air.  See this link for some more answer:
http://www.lessemf.com/faq-shie.html#Lead-Copper  and read through from title Why can't I just use lead or copper or aluminum foil for magnetic shielding?  to the bottom of that page.
Check also this link on this Forum for magnetic shielding:
http://www.overunity.com/index.php/topic,2217.msg29095.html#msg29095  The USA patent application is very interesting.
Gyula
