Thanks to ALL for your help!!
this might work - gravity - need help
Started by FreeEnergy, September 14, 2007, 05:43:29 AM
FreeEnergy
hansvonlieven what do you think?
i also changed from frame 111 to frame 108.
108 seems better
peace
hansvonlieven
G'day FreeEnergy,
I just had a look at your animation. Frankly, I am confused. The fulcrum of the pendulum appears to move in an arc. I do not know why you would want to do that but lets assume for a minute there is a valid reason. How do you propose to achieve this. Unless the entire assembly is mounted on the perimeter of a turning disk which is driven by a motor.
Tell me what you have in mind and what you are trying to achieve.
Hans von Lieven
FreeEnergy
i don't know what the mechanism will be exactly but from this animation it shows that the bigger weight is lifted up slightly because of leverage from the smaller weight. the bigger weight doesn't go up very high but the point is that at some point the bigger weight goes slightly up from its starting position and the system dies.
i don't know what the mechanism would be but after the system dies couldn't we roll the bigger weight horizontally back to its starting position. maybe the bigger weight disconnects from the system, and while it does that we get kinetic energy which somehow mechanically resets the system.
its still half baked idea, need help.
4:37 am. need sleep  :(
peace  :)
edit - forgot to add attachment.
hansvonlieven
G'day FreeEnergy,
This drawing is clearer, though I don't see where there is an advantage.
Essentially what you have are two coupled pendula, since the excentrically mounted flywheel (for want of a better term) behaves just like a pendulum under those conditions. A single pendulum with the same mass and the same distance from fulcrum to centre of gravity will have to be more efficient, since the two pendula in your drawing are fighting each other to some extend because the natural resonant frequency is not the same. The natural frequency of a pendulum is dependent ONLY on the distance between fulcrum and centre of gravity not on mass or anything else.
Hans von Lieven
