Tesla Switch need help
Started by TheOne, September 16, 2007, 07:27:52 PM
Groundloop
@Bessler007,
Quote from: Bessler007 on January 15, 2008, 12:21:45 AM
Hello Fausto,
A point from your first link:
  • I think that Mr Bedini wants us to understand the nature of things by ourselves, He doesn't want to spoon feed us, but wants us to understand.     .....elias
is pretty revealing for me.  Who is it that actually could reduce into a sentence or two the theory of this switch?  I need to be spoon feed!  I'm starving here!!
I've just recently looked at Tesla (I'm no expert) and his work and I don't see anything where he suggests that a closed system can generate energy.
Bessler
mib HQ
Quote from: plengo on January 14, 2008, 10:46:26 PM
@Bessler007
Here are some of the links with all the info you may find about this tesla experiment and some more.
http://www.energeticforum.com/renewable-energy/962-use-tesla-switch.html
Fausto.
The simple explanation of this switch is to put two capacitors in series and dump the charge to two capacitors in parallel on the other side of the transformer. Then reverse the process. The transformer has a low resistance primary. If we use switches with low loss then we can switch electrons back and forth many times before (the always present losses) will deplete the charge in the capacitors. We can not destroy or create electrons but there is no law in nature that prevent us from using the same electrons more than one time to set up a magnetic field in the transformer. The electrons that power the load is not the same electrons that we use to switch charge between the capacitors. The other variant is to use batteries instead of capacitors. In this variant we switch charge between the batteries via a low resistance transformer. The batteries will be depleted at the end but the free electrons we move in the transformer to the load is not the same electrons we switch back and forth so the net output MAY be greater than the total capacity of the batteries.
I personally do not know if this circuit (or the battery switching variant) works or not. So far I have been struggling to design a low loss switching circuit for this setup. In a day or two I will have my new pcbs. I hope that my new circuit will be able to switch between four 4,8 Volt 2 amps. NiCads without any big loss in the system. Time will tell................
Groundloop.
Bessler007
Thank you, Groundloop.  My initial sense is if what you're proposing is true, you're approaching the matter in the wrong manner.  I need to think about this a little more.  The crux of it might be in the rate work is accomplished or power.  You might have a point.
Bessler
http://www.bessler007.blogspot.com
Please try again. If you come back to this error screen, report the error to an administrator.
Paul-R
Quote from: Bessler007 on January 14, 2008, 10:22:56 PM
I'm wondering if you could post the theory of operation for the Tesla Switch.
Thank you.
Try this
http://www.panaceauniversity.org/Chapter6.pdf
Read page 18
...and then alter the URL to Chapter 1 for further information
which may be useful to know about at some future time.
Paul.
Super
Hello Groundloop,
I've read the thread and the paper you sent and also I've followed some of the links posted here.
I'm wondering if you could post the theory of operation for the Tesla Switch.  Also if there is a Tesla patent to reference that would be nice.
If anyone else would like to post a theory of operation for the Tesla Switch I'd be interested in hearing that also.
Thank you.
hi
Bessler007, in my opinion the only resonable theory is descriped over quantuumphysics.
Leadatoms have to be in resonance, timereversed effects can occur, chemical reaction is time reversed.
You can call me crazy but thats it.
For more information look at "Lawandy" "Boosted light: laseraction in white paint"
the effect equals in some  cases, but is easier to reproduce...
if i find the time, i will post some more references ...
Super
Bessler007
lot of reading.
The Tesla switch sounds to me like holding up opposite ends of a 2x4 at the same time.  I'm still thinking about it.
Super,
Electrons orbit but I don't think we know why.  If they're like everything else we know about there is some cause or energy input to allow them to work.
I don't think a Tesla switch can work if it's pulsed dc.  Tesla made the point of using energy that didn't make drastic changes (eg his turbine).  I think the switching has to be sinusoidal.  Just guessing here.  :)
