Circuit setups for pulse motors
Started by Nastrand2000, September 16, 2007, 10:46:33 PM
dasimpson
i have taken a dead psu apart and found these are any of them any god to use in a pulse motor 2sc2625 or this one 2SC5353
WilbyInebriated
i've used the 2sc2625 in a bedini SG circuit before.
dasimpson
Quote from: WilbyInebriated on November 08, 2010, 05:13:59 PM
thats god news then i have managed to salvage 2 of them.
is a 250 volt neon ok or dose it have to be a 110 volt neon?.
i have built a pulse motor with a reed switch worked very well on a hdd drive motor and disk 16 6x6mm neo mags but burnt out the reed switch.
so i made my own more heavy duty one but there was to much rf interference been created so hopeing the bedini style will work better.
guruji
Quote from: dasimpson on November 08, 2010, 06:56:45 PM
Hi Dasimpson to eliminate spark in reed put it between BR on AC side with low voltage diodes. Pulse motor have more torque.
dasimpson
what do you mean br ac side they is no ac side the power is from a battery
the set up went + of battery to read switch then to coil from coil to battery -
