Circuit setups for pulse motors
Started by Nastrand2000, September 16, 2007, 10:46:33 PM
guruji
 Hi Gyula thanks for reply.Can you please describe the circuit above cause there's no adequate info.
Those resistors example and what type of transistor is used?
gyulasun
Quote from: guruji on July 13, 2008, 10:56:26 AM
Hi,  you can find everything in detail at this peswiki page:  http://peswiki.com/energy/Directory:Bedini_SG
The fix resistor is 680 Ohm (the variable is 1 K, or 4.7 K Ohm you may omit it too), the transistor is 2N3055.
Gyula
guruji
Hi Gyula the funny thing is that circuit was given to me by Konzen.I think this guy knows what he was telling seeing his website.
Maybe I did not understood exactly cause he explained by words never posted me a scheme.
Thanks.
pese
Quote from: guruji on July 13, 2008, 08:40:16 AM
Hi guys I build one with a 2n3055 but after a while no emf was coming.
How can I switch on and off the transistor completely?
I'm posting a rough sketch of my circuit.
Any help please?
think EASY
the trigger coil are  producing  an voltage  to the base (if excuted with an magnet !)
-Think ; an very short time, like an "pulse"
so the collector emitter from transistor switch on ( like : close)
the fully battery power now flowing over the output coil for an short time.
After that the transistor open ( even over the diodes-bridges).
(Possibly with Back-EMF)
After that that start (trigger) again , of the moving magnet pass the next time the "trigger-coil".
It is very simply - you must give attention that the trigger coil produce (like an generator) enought power to drive the Transistor.
(Minimum 1,5 volts and 20 -50mA)
Pese
THE scematic from ARTIC is exactly the same with changes in the base currents.
BOTH circuits will work , but are not professional designed
guruji
Hi Pese or Gyula if the circuit of Arctic works can you guys give me the parts in detail please cause in the circuit nothing is explained?.
Thanks in advance.
