Circuit setups for pulse motors
Started by Nastrand2000, September 16, 2007, 10:46:33 PM
Nastrand2000
You can wrap them the same way for ease, then try connecting one way then the other. You will get the result of forward and backwards this way.
Jason
Nastrand2000
Interesting, one thing I just tried was taking a scope shot of the collapsing field  while running at 2 volts. The scope is registering 300 volt spikes. This is with the wider slimmer coil. That is the highest spike I have seen at this voltage. And just to be clear, that is charging a cap. However, the cap only reaches 60 volts (450 volt 1 mF).
Jason
tropes
Before I quit for the day ( I'm being told I should rest ), is there someone that can tell me why my Hall switch stays "on" from time to time. The pnp transistor( tip 107) doesn't change or is not affected.
Peter
Nastrand2000
The only reason I could guess is latent voltage in the system keeping the tunneling effect open. Get some rest.
Jason
Nastrand2000
well I found that cleaning out my bearings with acetone then putting motor oil in them (10w-30) allows me to run this motor at 1.5 volts. Now the motor runs very quietly and it puts out a continuous 40 volts, enough to charge a 12 volt easily.
Jason
