Circuit setups for pulse motors
Started by Nastrand2000, September 16, 2007, 10:46:33 PM
Nastrand2000
I agree with hoptoad,
Frequency is everything, this is why I showed my motors running so slow. I was allowing the resonance of the bifilar coil to to charge a cap thru the feedback of the transistor. The transistor can switch rapidly. Tesla did not have these products available during his time, but if he did he would have made great use of them. In order to allow the full feed back of the coils we are using, rpm must be controlled precicly for the most output (not necessarily rpm, but firing of the coil) . I think this is what hoptoad is getting at.
Jason
p.s. Hoptoad correct me if I'm wrong.
Ren
my basic theory is similar to that Jase. I believe frequency is very important. More so, I think that making a certain coil of certain length and construction resonate at a certain frequency can have unusual results. I have read that batteries have a certain frequency, imagine if it was as simple as hitting a battery with a certain frequency that would make it recharge? That would be something.
Nastrand2000
I believe you are correct Ren. When dealing with batteries, your dealing with several natural molecular and atomic resonance frequencies. There must be a corresponding harmonic to excite said molecules and atoms. When dealing with capacitors, your dealing with point charges, therefore every cap also has a corresponding resonance frequency. If you believe that string theory is the next step in explaining our physical universe, then one must also believe in virtual particle flux. That is particles exist and cease to exist within our dimension, coming and going. I believe that resonance may be able to harness this energy. A good person to study is Paul A. Dirac.
Jason
Ren
heres a pic of recent progress. Bedini circuit on three bifilar coils, one trigger three power. Adjustable rpm and amp draw via 1k pot. Two windings not being currently used. Rotor is hard drive 10mm cube neos n/s/n/s/n/s/n/s. experimenting with recharging via bedinis method and also off collector back to emitter. Both ways showing potential.
Video here:  http://www.youtube.com/watch?v=U0I2HtTu2Cs
b0rg13
if you want to get out of the rat race,you have to let go of the cheese.
