<THE WATER FUEL CELL BASICS>
Started by PULSED)ReverseH/OfuelcelI, September 20, 2007, 06:13:46 AM
Spewing
Pulse, i really like your work. you was the first that i had ran into when i first started testing the water fuel cell.  i really like the fact that you are taking action and not thoughts. Keep up the good work bud, i can see that you will get this working really soon.
Hydrocars.
raisdfist
Thanks for the reply! As for the freq genetator... the output would be from my soundcard right? also how would I hook this to my 5v power source from the out of my sound card without having power going back into the soundcard ? also if it is the case, would an amplifier helps? I got a 1000w Mono kenwood subwoofer amplifier in my car that I could use to play with this :) this looks a lot more promising than trowing a bunch of amps @ 12v in my cap :) I cant wait to play with that, I am learning so much since I started reading these forums and that I just build it! =)
Thanks!
Gheller J
Hey Pulsed)
sorry abt d delay in replyin     was pretty sick    still recoverin
What I meant by pancake bifilars was the one in d Tesla patent
He doesnt show u any core in d figure
Thanks for d diodes spec
How abt usin high speed diodes for d BEMF utilization? Any specs on which 2 use?
Gh. J.
TheNOP
Quote from: PULSED)ReverseH/OfuelcelI on September 24, 2007, 02:10:39 PM
A: the bifilar coil makes a better magnetic field.
False.
And you can be sure i checked out my faqs more then just once this time...
Serial bifilar create a capacitance that is calculated to be 250 000 times greater then in a normal coil.
A normal coil + a capacitor would have the same effect as the one you are trying to achive with serial bifilars alone.
Farrah Day
Hi Pulsed.
Nice write-up. But incorrect in many ways.
A couple of questions:
Everybody seems to assume - and indeed, in most cases - simply accept that the wfc electrodes act as a capacitor, but this is really only true when pure water with no impurities is used. Other than that its more like a resistor!
So, assuming we are only using normal tap water as supposedly SM did in his water car, and given that this is a very poor dielectric and hence makes for a very, very poor capacitor, how is the charge build up on the electrodes stopped from travelling accross the water medium at a relatively low potential?  Surely the potential difference across the electrodes only has to reach a very low level before the charges are a-off and travelling.
The other, quite important point is that the blocking diode actually stops the circuit from resonating in the first place. Flawed electronics theory I'm afraid.
Thanks. Farrah Day  :-*
Farrah Day
"It's what you learn after you know it all that counts"
