Lords of the Ring 2
Started by hartiberlin, September 21, 2007, 09:14:07 AM
supersam
@gk,
Thanks for everything!  keep up the good work.  I can feel your disapointment wheather anyone else can or not.
I hope you do not let this discourage you.  there are alot of us out here, that don't have your abilities that are counting on you!  If there is anything i can do let me know.
keep up the good work,
love sam
ps:  hope you have a REAL thanksgiving.
giantkiller
I am kind of late but thanks.
I will now spill the beans:
The circumference matches a 1/4 wave length of a frequency made of a harmonic from 2 frequencies. The harmonic is in relation to the outside environment! That is why SM didn't change frequencies but changes the length of the wires! Can you say guitar / amplifier feedback? Sine waves not square waves. You can thank BOLT for this.
At the 90d phase of the control of the clockwise circumferal return the control coils are pulsed again at the height of the magnetic field. An amplifying, pumping action is now in place. As the new field is impressed on the previous field there will now be new pressure cutting across the outer windings. This is 26x the speed of light per Podkletnov. Use an iron wire loop with the collector to accomodate an angular change in the flux collection. Remember the control windings are 90d perpendicular to the collector. The iron wire field will now cut the collector at a parallel.
If you want you can wire the end of the control wiring to the iron loop. The iron loop is open ended or closed(magamp). You can thank OTTO for this. Now the reason the iron loop with the collector needs to be horizontal is the planet flux passing over it is horizontal. The device bends the planet flux(weak field) down throught the center causing a vortex. Additive collection process. The flux must be bent. The clockwise direction is necessary in the northern hemisphere. Why? Same direction as draining water and the direction of the crown of your head. The collector in this position also reads the activity from the flux / planet like a directional antenna. This directional antenna is also involved in 'Effective Aperture'. You must read about that to comprehend. It is the same process that your ears perform.
Don Smith's device had slight problems at 2khz. SM used 5khz. Sm used a circumference of 4", 6", 18". The 15" didnt work.
I have pulsed a square wave into a ferrite toroid and gotten sine waves out.
Frequency #1: 35khz. Frequency #2: 6khz. Harmonic: 5.83hz
Or
Frequency #1: xxkhz. Frequency #2: xkhz. Harmonic of 7.83 Schuman resonance.
xx by circumference.
Anybody that has been involved in this for the last four years knows all the key points here.
Hope this opens eyes. There is still a puzzle in this description.
Merry Christmas, TPUers! You have 2 years till climax.
osiris
@GK
can you repost the the gold stactue pic of OSIRIS holding the ring ?
thank you
MERRY CHRISTMAS
IS  ;)
ps: i cant seem to find it any where !
osiris
guess not ... eh!
o well  far from my loss
ever wonder how it infact works ....  :)
guess not eh!
OSIRIS
i use 3 fingers to time the divice and turn it off and on !
;) just ask captian kir
just my 10 cents
giantkiller
I have it somewhere.
That also looks like 15c.
Quote from: osiris on December 19, 2010, 11:55:47 AM
guess not ... eh!
guess not eh!
OSIRIS
just my 10 cents
