Lords of the Ring 2
Started by hartiberlin, September 21, 2007, 09:14:07 AM
giantkiller
Before all go off half cocked: Merry Christmas and here ya go:
It is really quite simple as SM said. The guy is a genius in reconfiguration. Remember this: He kept pushing 3 windings, one with in the other.
He split the stungun transformer into its constituent parts by removing the iron core and replacing that with air spacing. This thing is noisy.
The charge pump circuit is in microwave ovens, Radar equipment, Automobile ignition systems, and TVs and many other systems that boost voltage.
I took the STUNGUTZ.jpg circuit and removed the transformer.
I built an LTPU out of plastic.
I then inserted the LTPU in between the stun gun circuit and the transformer matching the transformer coils with the LTPU coils.
The LTPU is 2 TPUs intertwined. Yep. There are two of them there. Why, I dont know. I guess SM wanted to further obfuscate the investors.
The outer side coils of the Center toroids become air spaced extensions of the retriggering coil. See?
As the charge pump increases in voltage the field expands inward to the center tordoids. Remember the amp meter in the middle?
This shunts the charge field into the FE wire collector. Think thumping.
Now in regards to the cabinet magnet that SM used. Halucinogenic prestidigative magic. I mean really. Watch what he does.
That is how he solved the switching between the starter battery(remember he mentioned a car?) and the regenerative pulsing.
I have been sitting on this since 2006 to ensure that SM, Mannix and others were 'Out of the way'. They spoke of NDAs but I believe they were showing the public limits and anything past would bring trouble. The rest of us didn't know either. I still do not know what the acceptable limits are, except no live demos and no videos are obvious.
There have been a number of radio engineers in the background helping release this but were not in a position to or wanting to be in the public eye.This schematic performs 99% of all the functionality and the protocol which the field video shows. In fact the video is all that is needed to get something working.
The distance between the verticals and the center toroids is the physical tuning. One has to play with that in accordance with their build.
The TPU little blacks boxes are stun gun charge pump circuits. This circuit is a model of all Tesla's builds. The charge field just shows up in different places.
This is what I saw when I covered my living room floor with all his patent pictures and why I mentioned the movie 'Contact'. I even went to the VLA.
Sm mentioned lightning. Yep, thats a spark gap.
Sm mentioned ramp up. I see that as the neon starters get warm. This could temporarily knock the system out of resonance. I have a hard time abating this.
That was when I realized the open tabs on the LTPU were shunt or jumper connections to hook the two fuses on the back into the system.
I was given a suggestion by an engineer to place an aluminum disc from a thin sheet of HVAC tubing on top of one TPU. Sparks shot out the sides like a corona. Shades of T.T.Brown.The open tabs on the center toroids' box are used for shunting, testing and measuring.
Every section of this schematic has been tested and shown in my previous videos and posts. Like I said before 'I have hidden nothing.'
Entropy is evident if the oscillator frequency does not match up with the inductance, capacitance, tanks and wire length.
I wound adhoc based up the ring diameter and height. Probably could have made tighter but I noticed a lot of stunguns are designed sloppily.My assumption was that sloppy was safe.
Just dont try to sell this and you'll be fine...
Unannounced visitors are never welcome.
MasterPlaster
GK,
What was the thing about the device geting too hot after 20 minutes and having to be shut down?
Quote from: MasterPlaster on December 11, 2020, 04:43:21 AM
GK,
Hello MasterPlaster,
The problem,the solution : 1 motor 1 cylinder workpeak     workaverage      temperature      efficiency  ?
                                                              2,3,4 ....cylinder ? motor workpeak workaverage temperature efficiency  ?
                                                1 solarcell : how many circuits/revolution processes in 1 cm x cm
                                                cold solarcell : % efficiency  best,average,
                                                 %efficiency scale cells/circuits velocity-speed  becoming warmer/hotter ?
                                               1 TPU power output per Kg  ,per gram(m)?
                                                Specific power/weight max. periodically/permanent     - preserve !
                                               1 TPU + 2nd TPU + 3rd TPU = 20 min x 3 = 1 hour work function ,inter-mediary !
                                                         TPU ,in use :
                                              RT ~ ambiental temperature global average 15°C, down ,up to 0° K ,supra-conduction
                                              In refridgerator,in freezer,ultra-cooler,in vacuuo
Sincere
OCWL
p.s.:
Schukey DELTA-OMEGA
        REVERSIBLE PROCESS
heat/cold engine,cold cascade ,showed the engine and process in the 80' in german BWM,Bundes-Wirtschafts-Ministerium',by Mr.Schukey( now R.I.P.,the inventor,2020 p.C.) ,down to
               Negative 180°C temperature~ density~ pressure ( liquid air CO2- filtering ? carbon reuse: graphene )
Source: Wirtschaftswoche,2020 p.C. Archiv(e)
Graphene for Nano-TPUs-Arrays ~ NOVASOLIX
related #35 Thomas Townsend Brown,whose co-operated with Nikola Tesla :
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=&IN=thomas+townsend+brown&CPC=&IC=&Submit=Search
"Gravitator cells","kings clothes"
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=thomas+townsend+brown&IN=&CPC=&IC=&Submit=Search
G-cells compared physical apparatus concept and external effect (Grebennikov cavity ?)
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=5&ND=3&adjacent=true&locale=en_EP&FT=D&date=19660823&CC=US&NR=3267860A&KC=A#
Prof. Dr. Hermann Plauson     https://en.wikipedia.org/wiki/Hermann_Plauson
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=&IN=hermann+plauson&CPC=&IC=&Submit=Search
only energy related
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=28&ND=3&adjacent=true&locale=en_EP&FT=D&date=19250609&CC=US&NR=1540998A&KC=A#
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=68&ND=3&adjacent=true&locale=en_EP&FT=D&date=19460425&CC=FI&NR=21227A&KC=A#
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=86&ND=3&adjacent=true&locale=en_EP&FT=D&date=19430424&CC=DE&NR=734794C&KC=C
"kings clothes" ? rubber
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=otto+traun&IN=&CPC=&IC=&Submit=Search
Tesla,Plauson related
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=39&ND=3&adjacent=true&locale=en_EP&FT=D&date=19220710&CC=GB&NR=157263A&KC=A#
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=40&ND=3&adjacent=true&locale=en_EP&FT=D&date=19220710&CC=GB&NR=157262A&KC=A#
Louis Charles de Beaupre surwatteur Ruhmkorff
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=&IN=louis+charles+de+beaupre&CPC=&IC=&Submit=Search
same invention level  https://www.nytimes.com/2008/05/31/business/31marks.html
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=&IN=alvin+marks&CPC=&IC=&Submit=Search
Magluvin
Hey GK
Thanks for sharing
In your first post on this 3rd page you have what seems to be a vid as an attachment. When I download it, it comes up a file. Not a vid file, just generic file. When I download again, and again, the name of the file is just some random letters, but each time I re download the letters change but the file is still the same size.
anyone else have this issue?
Mags
