Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
aleks
Quote from: poynt99 on April 09, 2008, 03:59:03 PMbulbs running off cold electricity have always been noted as giving off quite a different and distinctive glow compared to normal electricity
OK, do you have a link to video or something?
aleks
Regarding cold electricity, I had an idea that if you change the diodes on collector coil this way: -->|-- coil --|<--
It will produce "cold electricity" by taking more of external energy than giving off. Everything else in the circuit should stay the same. The reason for this is that we are hunting for "unspoken" potential field when running pulsing. This field can be both positive and negative with electrons running outward or inward, respectively.
poynt99
Loner,
no editing there. the ES coupling serves no purpose at all. it's an artifact, and probably a nuisance that caused SM's circuits to malfunction until he sorted out a solution.
don't leave pls :) I'm no quantum physicist either, just trying to learn a few things and contribute a few bits.
the phenomenon you and Jon are talking about is the Aspden effect, and spherics mentioned this as well.
aleks
Quote from: Loner on April 09, 2008, 04:05:47 PM
Thinking about all that was just typed buy you and aleks, it seems to me that I am not going
to keep up right now.  (Quantum theory has always given me a headache, ever 2+2=1.)
My posts are not related to quantum theory at all. It is basically: clap your hands. This is what happens when you are sending off sharp impulse along wires. In case of hands a heated air goes from under your hands. In case of wires, heat energy goes from under colliding electrons and atoms. BUT there is a little more than that happens. During this clap a "gravity-like" potential field appears. So, not only low and high frequency kinetic impact waves appear, but also this instant DC field appears (which is an attracting or repelling potential field for any particle or wave). I strongly believe this field is what made nuclear chain reaction possible for which to run efficiently an initial large-scale implosion is a necessity.
giantkiller
Poynt, Thanks for the clarification, but I guess I misread you post the first time.
(Maybe you edited it?)  EIther way, I am now a little lost as to what function that coupling
has and how it applies.
Unless, I am so far over my head that I lost the jist of what you guys were talking about....
I'll take my pi-mesons and bosons and pack it up.  You guys are beyond what I can put
into practice with my existing equipment in my personal lab, and access to the big lab
isn't on the schedule for few days.  I'll leave you to it till then.
Little note to GK:
While at IBM in the late 70's it was common knowledge internally that the channel cables
would have 6 to 8 signals on them when sending data at full speed.  I mean that the pulses
traveling down the cable hadn't reached the end before the next 5 to 7 were sent.  (The handshake
methods are probably still proprietary, so I won't mention their setup.)  In sending around
a circle (Coil, TPU, etc.) these pulses will meet!  Is this the effect you are attempting to
obtain with "Heterodyning".  (I hope so because that agrees with what little hard data I have.)
Could this be the "Source" of the "Kicks" and therefore the energy of the device?
Any comment you could make would be appreciated.
Art
The noisiest and most dangerous of my tests were the GK4. I pulsed 3 layers of 3 coils = 9 in a CCW of 12v @ 2.5 amps. Between the layers is where the magnetic fields ran into each other head on. High speed ejections occured. So I then pulsed with a stun gun = Bluish sparks. That is what sguns put out. But this occured from between the layers. Again all coils pulsed same way. I will set up the 3 freq panel I built and fet the GK4 again. This time the middle layer will be reverse pulsed. The panel is 1mhz max and does sine, triangle, square with dc offset and amplitude control.
We have seen bluish sparks from the shorting test by SM on the SM17. Stun gun sparks are not hot either. Purplish dartlets feel lightly fuzzy. :D
Ok, how about this. I will attach a filament bulb and attach it to a stun gun. Will it light? Then I will make a bigger step stage and see if that drives a load. I keep seeing the SM17 just like this. What if the energy is not allowed to spark but get dioded into another coil to a load? Use the last coil and caps to downgrade the energy level into a slower more usable form.
The sm4 and sm6 drive 1 lightbulb to produce heat to light.  The SM17 10 lightbulb test is this also. Not that it can drive 10 bulbs. Ooooh. But to divide the power down. In another test to drive standard voltage devices, the SM17 is hooked to an invertor. SM states it is modified. What if the statement just means that the convertor is doing something special? The caps in the invertor are actually functioning normal but will a special incoming parameter. Faster energy. The caps love it! Who would know?
--giantkiller. Well this was a well needed read.
