Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
aleks
So, things start to materialize? :) I told you - these are DC acoustical waves. :) The thing is that scientists at the moment have no clue that spinning air at 5kHz is caused by DC acoustic wave formation (which moves air around like a cyclone does it with air masses). So, this spinning is a result, not a cause. Combustion is a good feeding ground for DC acoustical waves. I personally think that internal combustion engines should be eliminated on the planet once and for all. They are vampirising bio organisms.
aleks
Quote from: giantkiller on April 15, 2008, 10:38:26 AMAttached is the circuit that took out my scope.
This may not be of help, but one thing to consider... Charge will try to spread itself evenly, so even if you are having a single connection there will be some charge movement in the unclosed part of circuitry when spark gap fires. This is how Tesla's one wire power transmission worked - it used a spark gap as well. This may well be beyond normal engineering book knowledge as this allows to build sequential circuits - much like computer programs work (a=b+c,d=a*0.5, etc all in sequence).
giantkiller
Quote from: aleks on April 16, 2008, 08:19:02 AM
So then, yes. Each of the 2 loops in the SM17 would be driven in opposing directions. 5khz on a DC bias. We are not exciting the coil but the magnetic field of the DC bias with the hash on top which appears on the outer most part of the mag field or in the center.
Of my 4 coils at this stage the RE output is available. But the next stage has to be done right. My dogs actually became a great indicator to the possibilty of group damage. I can't even go there. I could have attached numerious solutions to the end of what I have now but it is not safe to flick matches in the gasoline. I have spent a year now watching and researching for the safe connection. I can hook up any high inductor / low inductor / high voltage / low voltage / high current / low current coils with diodes and caps but that is haphazard. That is the answer right there. Just get the right combination. No long winded diatribe needed. No reverse engineering needed. I am in a live environment now and have to be very careful. I don't want the neighborhood pets dying off from stress due to any mysterious effects when it could be me just blasting away. Dehydration due to convulsive bodily output. I am at the epicenter of all this energy.
The Tesla patent 464,666 in the cutaway of the 'A' coil shows a very similar coils technique to the 2 winding Tesla coil. I am counting windings again. Nik showed this level of detail in the 390721 transformer that I counted and made the GK4 from. To the Tee. So I do it again.
--giantkiller. The book of matches holds 20 fires only the right intention is the light.
aleks
Quote from: giantkiller on April 16, 2008, 11:21:46 AMEach of the 2 loops in the SM17 would be driven in opposing directions. 5khz on a DC bias.
Why 2 loops? Are you deducing that from the fact SM's TPU didn't work when turned upside down and running 2 loops was the only way to fix that? I believe there should be no difference unless your TPU is poorly crafted and some of its wires misplace when you turn it upside down. If I'm incorrect, can you answer will the TPU work if placed vertically?
Quote from: giantkiller on April 16, 2008, 11:21:46 AMWe are not exciting the coil but the magnetic field of the DC bias
Yep, it seems the case. However, what we are really exciting is gravity force (or something like that) around the pulse coils. This force then amplifies the DC bias energy. Since this is done in a cyclic manner, an EM whirl is created with an ever increasing energy. I believe hash is simply a bit of induced energy from the control coils. It should be minor, nothing to worry about.
Quote from: giantkiller on April 16, 2008, 11:21:46 AMOf my 4 coils at this stage the RE output is available. But the next stage has to be done right.
Yep, this may be dangerous. If DC acoustical wave nature of the amplification is valid, all you need is to start at low voltage pulsing and increase it until dogs start barking or geiger counter buzzes too much. Well, this may sound like a sci-fi, but DC acoustical wave should be used for telepathy especially considering dogs are so receptive to your experiments. This is also in my hypothesis - this is a reason combustion engines put a lot of stress to our humble bodies and brains.
giantkiller
Quote from: aleks on April 16, 2008, 11:58:27 AM
Agreed to all,
The 2 opposing loops are really a spin accelerator with the magfields hitting each other between the loops. Mobuis action horizontal and vertical.
The SM6 worked as SM held it down in front of him with the light bulb attached.
--giantkiller.
