Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
aleks
Quote from: sparks on April 18, 2008, 10:54:23 AMI can see inertial frames with potential energy in them relating to each other.
Potential energy can only exist if inertial frames have interaction between them in form of static long-range forces. It is this static force - which can be stressed by investing kinetic energy of inertial frame - that stores potential energy. It's actually Newton's law of action and counter-action expressed differently. That means that when you are stressing a static force field of object A by static force field of object B which have velocity relative to each other, there will be a maximum distance to which these objects may come into contact. At this point their kinetic energy will be zero and their potential energy will be equal to "invested" kinetic energy. I'm also having a speculation that due to the fact that static long-range forces have an infinite length of their reach, any two objects can never be at a rest relative to each other: they will always be repelling, even light years from each other (considering an ideal conditions where only two objects exist in the Universe). This is supported by a cosmology paradigm of expanding Universe.
Going a bit deeper, I would speculate that static long-range force is represented by gravity/antigravity itself. I'm also pretty interested at this point of time by Keely's atomic/molecular model.
( http://www.keelytech.com/ )
Each ring in this diagram is a static long-range force field. White being gravity, black being anti-gravity (or vice versa). Before starting to laugh you should consider the fact that planets orbit sun on approximately a plane. Probably for a purpose, which may arise from gravity interaction stability reasons. Internal atomic structure may be also "dictated" by such reasons.
giantkiller
Quote from: innovation_station on April 18, 2008, 10:08:38 AM
in the 6 freq bucket or the "Keely Bucket" this is 1 use for it...
look at the sm 17 the balums  ;)
now steel core or iron or ferroite  absourb the flux where as plastic coper or alum repel or reflect the flux or i guess you can call it internal flux or external flux  in the sm17 i think we use creative engery from{ the inside out} oposed to destructive {from the outside in}
if a coper core  or plastic  were used we could create a magnet external rotating vortex from the center out  and the collector be set into the standing wave  or ring if you like  wich will be located outside of the balum  at a distance deturmined by the freqs also the size of the balum ring might just reflect the size of the outter collector to a ratio not so sure ......
or you could use a balum and saturate it .....  till it spews out every where  if this is the case you could use a 5 watt tube amp and a few 4 ohm coils wound on a plastic core or a ferroite balum
also i dont know about the freqs as far as i have seen you can mix any freqs and by adjusting just 1 of the freqs you can change dirriction of spinn as well as the speed of the rotation so .....
all that being said
some one must try it out
ist
Let it rip, dude!
You and me both know you don't have to turn up the volume for loudness when the waves meet up, eh?
Remember to be the only human in the vicinity when testing. And secure all loose objects. Put a closed plastic container of water with black pepper in the bucket during testing, not your body parts. Hang plastic beads from strings down into the bucket from a wooden rod laid across the top. Duct tape it down. ;)
And I wouldn't be surprised that the Keely diag 5 shows the interactions of the acoustic waves when the spinning occurs.
Like shooting fish in a bucket, er barrel. Believe me, it sure beats using your domicile.
--giantkiller. Flirting with disaster. Always.
acerzw
A fantastic amount of good work going on here guys... its great to see.  :)
That Keely diagram is fantastic and has been a focus of my attention in the past, yet it always comes up again. I am sure it will reveal itself to have many more meanings in the future... The level of tuning that Keely went to in his experiments shows how subtle the forces can be when not contained in a bucket!
@Is
Hope you post some good pics/video of it in operation, somewhere, its going to be a fearsome beast! Shame about the file size restrictions, I'm a visual person, now instead of a decent picture we often have to read a 1000 words... ho hum
A
In a Holographic Multiverse everything is smoke and mirrors!
What is Reality? Improve yours: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13459
A shorter version for the very open-minded: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13866
Localjoe
Some very interesting data.....
"Tenan?s discovery, made way back in the 1960s, was that the Fibonacci spiral is the apparent basis for the Hebrew alphabet, as well as the Greek, Arabic, and Sanskrit alphabets, making it the root of the universal language used at the Tower of Babel. It all started when he discovered a pattern in the original Hebrew letters of the first sentence of Genesis - a pattern that appeared when he counted the letters in base three. He then placed these letters into geometric shapes based on that pattern. When placed in a square shape, with like letters placed next to each other in concentric square rings, the result was what looks like a ?bird?s eye view? of a seven-stepped ziggurat like the Tower of Babel. When this was then placed upon a torus or ?doughnut?-shaped surface, and the excess space stripped away, what Stan Tenen had was a three-dimensional representation of the Fibonacci spiral, a shape that can be found in numerous occurrences of nature, including the shape of a developing fetus, and the horns of a ram. This somewhat snakish, flame-like shape Tenen then placed inside of a crystal tetrahedron - a four-sided prism or pyramid. When light was shined through the object in a shadow-box, Tenen found that he could form every single letter of the Hebrew alphabet - in order - just by changing the position of the shape relative to the crystal. With a slightly different orientation, he was able to produce the letters of other alphabets as well. Appropriately, Tenen named the shape the ?flame letter.?
The Fibonacci spiral is a representation of the golden mean proportion that occurs so often in nature, and which has been used in all of the most magnificent works of art and architecture, going back to ancient times, including the pyramids at Giza and presumably, the Tower of Babel. Even the colors of the rainbow are made by different wavelengths that vary in size in a golden mean proportion relative to one another. This can be seen in the varying widths of the color bands in a rainbow. (4) The seven colors correspond to the seven notes of the diatonic music scale, and the mathematical, golden mean relationship between the notes, as they ascend and descend along the scale, matches exactly the relationship between the colors of the rainbow. The fact that colors have musical equivalents is reflected in the twelve-note ?chromatic? musical scale. As described by author Michael S. Schneider in A Beginner?s Guide to Constructing the Universe: ?The chromatic twelve-scale includes the diatonic seven-scale plus five sharps or flats between them, giving the scale shades of musical color.? (5) This may provide a factual basis for the sensory phenomenon known as ?synesthesia?, in which certain people naturally see certain colors when they hear certain sounds, and vice-versa. Such people often report seeing the letters of the alphabet in certain associated colors as well. The modern musical scale system used in the West is based on that invented by the ancient Greeks, and attributed to the sacred ?lyre of Apollo?, which also belonged, in turn, to Orpheus, Pythagoras, and originally, Hermes. Schneider writes that, ?As one stroked the strings upward, the tones descended to earth through E-D-C-B-A-G-F.? Elsewhere in the book he states that the scale would be ritually strummed by priests in order to call angels down from Heaven!"
Joe
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
Localjoe
http://anightinrome.blogspot.com/2007/06/la-porta-alchemica.html
"The monument has numerous symbols and inscriptions used in alchemy, and legend has it that if you say them in just the right order (unfortunately unknown) and pronounce them perfectly you can get through the door and presumably return with goodies from another dimension. The inscriptions are hard to read from the monument itself, but they are (supposedly) faithfully transcribed on several Internet sites, some of which are listed below."
