Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
0 Members and 35 Guests are viewing this topic.
giantkiller
So if I use a frequency that is dead on resonancy, which is the lowest current setting I could never get the rising edge to hit anywhere else in the ramp up, ringing window. If I jump up or drop down then hit the window elsewhere the current goes up. ;D
So I could use FSK with a alterable center frequency and a controllable window with. Still one frequency. I could use a triangle wave to control a variable or blocking oscillator. Or a saw tooth. Ooh boy. Or just drive it with a triangle wave and see what happens. Could be all the control I need. ;) Or since my affects happen on the trailing edge I could use a ramp up quick off saw tooth. Up, up, up, up, Bam!
--giantkiller. Stuck at work and dreams abound.
giantkiller
Quote from: bhaas on May 27, 2008, 11:29:26 PM
@GK
That answered another one of my questions. I got a some more  ;D
I'm reading the 382282 and was wondering if Tesla connected the 2 ends
of coiled steel wire or did he leave them unconnected?
I fully understand the mechanics of the diagrams and his descriptions of how
to build what's illustrated. Another question I have is whats the plan to keep
one of these running on it's own?
As for the "flow" of electricity. I'm stumped on that one. Does + goto - or ?
Which is best to pulse with? + or -
What about using a DPDT relay and have it running as fast as it'll go on its own
and pulse +- at the same time or have it alternating +- on each throw.
Either or. Try both I guess. I'm thinking that give it a good kick.
I remember reading something about reed switches. Hmmmm.
As you can probably tell I'm no EE but I'll get it as I go, and once I get going
I'll pick it up fast. But all things mechanical, no prob.  ;D
Brad
Yes, But you won't be able to see the part that is flying through space. It isn't mechanical and it can kill you.
--giantkiller.
giantkiller
So here I have an even better wave.
31,250 hz, square pulse of 12v, 400ma.
The blank spots are the driving pulse on times. The envelopes are the pulse off times. It can be seen the ringing is greater than the input. My suspicion is the bell shape is because my ring is oblong. ;D Ths has to remedied into a ring for the central position of the waves to react.
--giantkiller.
bhaas
Quote from: giantkiller on May 28, 2008, 01:34:06 PM
--giantkiller.
I'm aware of that. Was doing some high voltage experiments a few years
ago and go hit a few times from back emf going into my plastic push button
switch I was using. I used a plastic rod to push the switch. No more shocks  ;D
In this C&P of the Tesla Patent 382282 he mentions the efficiency is increased
by the subdivision. Meaning he cuts it in halves/quarters??? Isn't that what you did
and put mags inbetween the cores? The more I read this the more I figure out.
I should have something done this weekend. I wish I could do this at work  ;D
Brad
giantkiller
Quote from: bhaas on May 29, 2008, 01:02:48 AM
and put mags inbetween the cores? The more I read this the more I figure out. I know ;)
I should have something done this weekend. I wish I could do this at work  ;D It is good to have the space away to think Else you'ld be winding your fingers off.
Brad
The points that I show and the leads to read are actually more productive than spoon feeding pablum. Less questions and faster mind travel.
If you wind the coils on those soon to be empty rat shack spools then the air gap exists in the spool. ;D
The 382282 is in quarters. The gke2lego_pmh is in halves. But when I add the iron segments then I get quarters, kinda. I am still continuing with the NT382282 build. Work smart and produce more. And if this should not be the last step, the results from this build have been the best so far from any thing I have seen. The other builds all lead up to danger. So far this has been just equipment loss. ;)
Dont rush. What you are working on now does produce great artifact. I have not seen these waves before. And they are Jahweh phat!
For all the Christian readers I repeat this. Ask once and receive a thousand fold. It is in this last wave. I pulse in 31khz and get 5mhz!  It ramps up. There it is on the scope shot. 'I ring the Bell' exclaims Quasimoto.8) But it grows!
And in regards to the previous post about Gnaural2. Go get it. The brain loves sound. This program heterodynes in your mind!
You want be to happy? Pick a freq. You want to be productive? Pick a freq. You want to produce? Pick a freq. You want to get high? Pick a freq.
Doggy treats for the brain. Avoid the noise.
I am back on the bench tonight. I will raise the 31khz up to 40khz - 50khz. I added coils and did not adjust the input parameters. And put fets in parallel.
--giantkiller. If yer not having fun you're just sluggin' along.
