Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
Grumpy
"If you only knew the magnificence of the 3, 6 and 9, then you would have a key to the universe.? - Nicola Tesla.
I have never understood what Tesla was referring to when he made this statement.  Any of you ever figure it out?
        -Frank Edwards
giantkiller
Quote from: Grumpy on June 22, 2008, 11:43:59 AM
In the heterodyning tests I did, I got very pronounced banging in the house. The aluminum heating ducts even rattled. That lead me to believe that some combination or multiplier with these factors is what has great power associated with it. I was going to use the GK4 in this combination test and with out the resistors. But I felt that field again and wanted to be safe.
I am sure the 3,6,9 fits in other places. Otherwise at this point I don't see all the possibilities yet. I have a list of tests to get time on.
And I am sure I, myself,  am missing some things.
--giantkiller.
aleks
"3 6 9
John Keely, wrote that the vibrations of "thirds, sixths, and ninths, were extraordinarily powerful." In fact, he proved the "vibratory antagonistic thirds was thousands of times more forceful in separating hydrogen from oxygen in water than heat." In his "Formula of Aqueous Disintegration" he wrote that, "molecular dissociation or disintegration of both simple and compound elements, whether gaseous or solid, a stream of vibratory antagonistic thirds, sixths, or ninths, on their chord mass will compel progressive subdivisions. In the disintegration of water the instrument is set on thirds, sixths, and ninths, to get the best effects." aqua1.txt from keelynet.com "
Also read my speculations I posted earlier... These 3-6-9 harmonics of 1 may be embedded into our reality as means to CREATE (for and by the Creator of all). Just think we are living in The Matrix and relieve your stress. ;)
(attached is a 200 Hz sinewave with 3-6-9 harmonics... increases libido upon listening ;) )
And a waveform... Tesla was using Fourier transforms so he was surely aware of time series and harmonic periodic signals. It does look like a KEY after all :)
"the magnificence" may mean magnitude of each harmonic... What you hear in the file and see on the picture is my personal mix of harmonics.
Grumpy
Tesla says "the" 3, 6 and 9, as if each is something tangible.
        -Frank Edwards
aleks
Quote from: Grumpy on June 22, 2008, 11:59:52 PMTesla says "the" 3, 6 and 9, as if each is something tangible.
Not necessarily. "The 3, 6 and 9" may semantically mean "exact 3, 6 and 9".
