Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
giantkiller
@singerxyz,
Great. I'll just push the tranny pkg by CE voltage adjustment size up to t-220 for the first step.
Sm stated that he spent hours snipping wire for resonancy. I have my first 4";diam stranded copper 4 turn collector. I am going to wind 30#awg at 120d sizing. Then find the resonancy for that mass. For the math that would be gauge, total length, turn size, # of turns. I can wind at day job. Check resonancy after to match a set of frequencies for the Schuman freq harmonics. Alot of talk about this has happened throughout the threads at OU here. It should be obvious now.
I still feed the OU monkey on my back. I got so many parallels coming to fruition because there are many ways. Class 'A', class 'A/B', class 'B'. HeHeHeHe... I got it all on the bench. Tubes? There are many amps available and to build a osc is no big deal. People tend to apply logic through prejudicial eyes.
--giantkiller. Total fun all the time. :D
sparks
   Alot of the circuits I see here are linear amplifier circuits.  I would like to build a tpu but reinventing the wheel is not a thing I want to do.   This unit looks like a radio wave transmitter antennae wrapped around a torroidal coil receiver.  Matching the antennae to the input pulse in order to reduce standing waves of radio energy in the transmitting ciruits is a common practice. The geometry of the transmitter receiver is most unique.  I believe this unit works on a principle I call quantom desire.  (Basically organization of electro-magnetic quantom is intelligent and has it's own will)  The kicker pulses allow the electrical quanta to behave as it might in space far removed from the quantom desires of dense highly organized quantom (strong quantom). By propogating and radiating before ambient magnetic fields influence their behaviour the kicker fields travel at the speed of light into the collector.  Released from the magnetic influences of the atomic neucleus where they have  been spinning and orbiting for millenia. (Now thats energy storage)  they move as they will.   Placement of a collector winding outside and inside the wrapped collector ring would boost this units output.  Once inside the collector it travels through a dense electron rich cloud of like quanta where it finds little magnetic entrapment.  Something like being able to run around the edge of a crowd 100 times faster than to move through the crowd. I digress big time.   I am sure that someone with a working TPU has data on both the kicker coil configuration or impedance and the corresponding frequency employed to get a good match.  This is the vital information and would be most helpful in my build of this unit.
           I realize that this information represents years of work but my intention is to build study and scale a TPU.  Not for personal gain (I've got enough and been through the patent game a few times. Got one to exchange if you want it) but for my grandchildren and there grandchildren etc. chances at a better life.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
kames
Hi giantkiller,
SM did spend hours and days, if not years, and he did say it, for fighting what he has discovered, but I don?t recall any document published in this forum mentioning what you said.
I have scanned all my documents collected from this forum and didn?t find it. Can you point me to any document mentioning it? The reason I am asking is that I am also working on a ?kind? of resonance and I would like to read again what SM said about it.
Hi sparks,
?Once inside the collector it travels through a dense electron rich cloud?.
There is no electron cloud in the solid core. Even so, if there were electron cloud in two first SM?s video, taking such a unit in your hands would disturb it very much and break the unit operation.
Kames.
giantkiller
Quote from: kames on November 10, 2007, 07:46:03 PM
Hi giantkiller,
From Kames:
I caught wind of this somewhere in all the threads. OU also changed blog servers over the past year and also, unfortunately, posts have also been deleted.
I have a mind like a steel trap when I hear something that fits the current stream I am on.
--giantkiller.
giantkiller
Quote from: zapnic on November 12, 2007, 09:20:48 AM
there is pantent page where is the picture but you have to bey money to see it  :P
but there is some thumb images that page
but they  all something do with metal detector
and its clue
sm word's
About the collector:
It is three separate coils of multi strand copper wire laid one on
top of the other, not interleaved.
Three is important.
You can do many things with three coils.
You can run them in parallel, you can run two in series and one in
parallel, or etc.
You can run a separate frequency into each coil for better control
on large power units if need be.
The control wiring is vertically wound in several segments around
each of the horizontal collector coils.
Other control wires are wound around all of the horizontal
collector coils together.
Listen, you need to make three coils or so one on top of the other.
But the important thing is to wrap the control coils perpendicularly
around the collector coils.
There need to be three of them all the way around.
start them up one at a time each.
First frequency then second harmonic component into the second,
then the third.
coil's three of them "horizontal circle wire"
they are creating three magnet pulse "cannon theory"and earth magnetfield respond with  Reflected Pulse
and the right frequency its become super powergenerator
and middle of tpu magnetfield is changing rapidly and there is the toroid coil and what happend when magnetfield changes  ;D
kicks and electricityyyyyyyyyyyyyyyyyyyy!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Yes, my fellow pursuers! This is the model I have been working off of for over a year now. This is the semi open model to start from. Just build it and drive it. You will see. After this you just flip things around like no tomorrow. The effects will show what Tesla is talking about. Pump it up! It might not be the finished model but when you see results then you will know what 99.9999999999999999999% of the rest of the world doesn't know!
Stage 1: Just build it.
Stage 2: pulse it incorrectly and blow shit up. Quantifiable results!
Stage 3: pulse it correctly & coordinate the driving configuration.
Stage 3: feedback to recouple the power.
I have been thinking about the difference of the Class 'A' , the Class 'A/B', 'B' and where the wave sits in reference to ground. But then I when one step further. The square pulses intrigued me as to where the radiant energy was coming from or how it was generated. A non-zero crossing wave has fields potentials going in one direction. But when that wave crosses zero the poynting vectors are now in opposition. When square waves are used that are above zero ref. the very high transit of the leading or trailing edge twist the vectors at high speed. This interaction is fiercely in opposition with our level of existance in this physical universe. This is the same as the sine waves crossing the zero ref. The copper is stressed in reverse by the high speed collapsing waves and pushed in the opposite direction. This produces very powerful effects. But if we keep the sine wave above zero reference the field never reverses and we are harmonizing with the level we exist at.
--giantkiller. As we squeeze the hose the canon balls remain traveling in one direction!.
