Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
giantkiller
@Localjoe,
This is way cool. I love a good cipher. You had posted the 2 scales before. This is one of those sets I believe.
And straight out of the Bible states: And the stones will cry out. What is there is a huge amount of ciphers all over the world that have been protected by those of faith as Holy remnants. Wouldn't that be a kicker. Alot of artifacts have shown this over th elast couple decades.
@Bourne,
I had made a 3 segment pcv ring with just this magnet configuration. The heterodyned output is very high speed in the gigahertz and terahertz.It might be a little different that the incorporation with the Bedini setup. I also had a coil that I dismantled. Aargh!! I have a gathering up the vids from before to post on youtube.
--giantkiller. Feed the need. 8)
giantkiller
bourne
@ giantkiller
The magnets in the Bedini rotor are the 'finger' that flicks the switch. There are circuits that use 555 ic's to do the switching, but you can't extract torque from a chip! ;D
Do transistors that switch in the terahertz range exist yet?
Could you switch a transistor and charge a coil with your heterodyne'd output?
What would happen to a lead acid battery if it was pulse charged at this speed?
I'll go and get my goggles! ;D
8) Ready!
There is but one true power in the Universe... that which we call Love. Todays present label and conspicuously absent from our named guardians tool kit.
giantkiller
The ss devices don't but the heterodyned output does no matter what the devices are. That is what Keely was proving.
I'll restate this: The Bose/Bolt heterodyning, the Bucket -o- vibes, the IS Audiohenge all produce audio heterodyning. Each step here went further into heterodyne focusing. The Bose/Bolt expressed outward from the single sound source made of 3 channel audio. The bucket -o- vibes expressed inward focus from the 3 sound sources. This produced the controllable rotation. The Audiohenge then expressed 3 centrally focused sound sources in a larger model. Again, inherent rotational controllability. But these were all to show the possibilties in audio. The next step I am taking is to apply this to 9 magnetic fields in the rings. We all know there are many different ways to make copper snap and sing. I am involved in one because I believe this one does it all.
--giantkiller.  You shake it, you break it!  Any way you want it!
armagdn03
@GK
Do you have like a list of snappy things to put at the end of your posts? Lol.
I wish I could turn my brain off sometimes, then I could get some sleep.
