Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
giantkiller
I have 3 fets driving 3 segments of the 1st layer. 100ohm 1/8 watt on the gates. 50 ohms 10 watts on the coil to +12v. The coil is on the drain and the source is ground.
the 3 freqs are around 100khz. The fets run run cool.  :)
The next step is to connect up the segments on the other layers in a spiral fashion and drive that. I need more fets or run coils in parallel.
I included a scope shot. The pulses are 14vdc. The output is +47volt height. ;)
One thing I would like to know is what the height of the field is in comparison to the height of the pulse in volts.
--giantkiller. Another step forward.
acerzw
In a Holographic Multiverse everything is smoke and mirrors!
What is Reality? Improve yours: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13459
A shorter version for the very open-minded: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13866
acerzw
An Alternative, a frozen (solid state) one is better I have heard.
A
sparks
  @gk
      What is you signal input?  If your up round 100khz your not inputting  audio anymore.  I have a 24khz 100watt amp that was used for an ultrasonic cleaning tank.  (I have a 0-10k supply but the finals are blown and the eprom set up for 1k ac output)  The 24khz supply also has a freq.sweep of about 4khz so that should be intereting. The ultrasonic amp is pretty hardy.  I also have some piezo electric transducers but don't see a way to use them unless I rattle the krap out of the coil mounted on a plate in front of some magnets. :D
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
