Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
sparks
   @GK
    1hz :)  It goes alot lower.  How bout lightyear long wavelengths with enough energy in them to rattle galaxies.  Take a little time to set up a receiver though. :D
And yes I'm really focused on whats happening on the magfield interface.  That's where the action is.  The collision zone between the Earth's mag field and the ring current mag field.  I'm thinking along the lines of putting together two distinct rings of different masses and tapping the voltage differential between the two.
Electrical tornado of sorts.  Low spin high mass coupling with high spin low mass and put the light bulbs in the middle.  Tesla primary lots of mass. Tesla secondary not much mass.   Lots and lots of voltage differential.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
giantkiller
Quote from: sparks on March 14, 2008, 04:55:09 PM
   @GK
Take 50' of formable 1/2" od copper tubing. Spread it out along it's axis to achieve about 1foot between turns. Spray it down with PAM nonstick spray. Take equivalent length of clear 3/4 tubing and slide it onto the whole length of the copper tubing. Squeeze the coil back together so the turns touch and secure in place. Place on an inverted trash lid. Drive to a large dish output location. Connect with jumper cables to Spark plug #1 on your truck. Place unit on ground, not in truck bed. Gentlemen, start your engines! The FCC should arrive momentarily. ;D
You can also place spools of wire on a post and connect all sequencially. Do not touch the ends? Hows that for a backyard Tesla coil?
--giantkiller.
Feynman
Thank you to all for providing information.
I will be persuing both analog and digital paths.   ;)
sparks
Quote from: innovation_station on March 14, 2008, 11:36:41 AM
intresting joe
hey im not sure guys but i dont remember TESLA beat boxing but perhaps he did .....
my lil pic  ;)
IST
Where is your motor innovation?
Tesla was convinced he needed line of sight to get his signal out there.  No bouncing freqs off the ionosphere for him.  He didn't believe it existed.   Plus it was too unpredicatble if it did.  This man was going to build an ionized air column 36,000 feet tall and send vibrations up and down that puppy.  No wonder they named the ionized air mortar after him.  12 stations located around the globe could be line of sight at that altitude.
Think Legacy
Spread the Love
Localjoe
@Sparks and All
Sparks i disagree with what your saying.  Your moving too far into unknowns with your theory. Im sticking to the facts . Here is my proof
A. Phi 1.618 and mathematical/musical intervals thereof are considered pleasing to the Ear. People who have facial features that line up with the ratio are considered to be attractive.  These are established facts tested and reviewed many times. I know may builders for custom homes that use these sets of ratios in much of what they do because the customer will "like the appearance"
B. This Link shows the recursive nature just as found in phi only two freq needed to find the rest http://educate-yourself.org/pnl/solfeggio01dec06.shtml- ACER CHECK THIS OUT!!!
C.  Phi and harmonics there of are repeating and if heterodyned with other "just tempered" freq they are CREATIVE .. this is a unique property. Not all wave forms combine positively.
D. you wrote "mass is harmonic frequencies cast upon more harmonics cast upon more harmonics"  This supports my claim..  The harmonics of phi add together to form more freq/overtones that keep increasing in there intensity and freq out of our comprehension.
I can keep going .... Hopefully you don't think this is nonsense anymore.  Just go look at a seashell i think theres something to it. as well Phi and Pi are two completely different things i just wanted to make sure you didnt think i was speaking of the latter.
        Joe
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
