Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
Localjoe
So here is what I propose
This tpu in this construction is made of 2 of tesla's "ring transformers" shown below stacked on each other with a wooden ring in between them .  Thoughts?
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
giantkiller
Quote from: Localjoe on March 20, 2008, 05:14:11 PM
Well as easy as it was to cut through I had posted expanding foam. The cutaway showed close to this with a lower and upper coil of what looks like lamp wire. Very easily driven as 2 multiple loop Helmholtzs. The center coils are the feedback to a VCO. These are another set of parameters to the BFG.
Or 4 ozone generator coils in a ring.
--giantkiller.
Localjoe
GK,
Yea the foam is more probable you right it was quick. There were two secenes of them cuttign the first one stops aberuptly after you hear the blade ting off the first ring. The guy had a pair of dykes in his hand in the second scene to cut what he couldnt. I really think that he used closed iron cores the big one. The coil shape is dam near perfect youd have to be winding on something that was cylindrical to have it look like that in the end.
CTG Labs
There is no iron core!  He cuts through it in seconds with a jigsaw, then there is a lone wire at the end which he grabs some wire cutters to cut with.
With the smaller versions he tells us the weight, too light for an iron core.
You can clearly see that he has cut a wooden ring out and this helps the shape to be nice and round, in fact he tells us as much.  Plus someone places a magnet around the outside of the large version and it does not stick.
You can clearly see 9 piece of thick mains cable from top to bottom when the slice is removed.  Probably then 3 collectors with 3 turns each.
I would love to see a jigsaw that could cut through an iron ring in 5 seconds!
In the video, regarding the large 17inch unit it can clearly be heard, 3 coils round the ring, there is no metal, just wood.  Why we have to go over this again and again and again!
D.
turbo
I have uploaded some pics into the download selection.
There will be more but i need to spread the pics over 5mb folders.
As for the cut to piece unit the pics are here:
http://www.overunity.com/index.php?action=tpmod;dl=get18
M.
