Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
0 Members and 16 Guests are viewing this topic.
ramset
More goose bumps  you sir are the pinnacle of inspiration  I feel like I'm getting to stand next to a pioneer that is pointing the way to the future  an absolute privilege  Chet
Thanks Grandma
giantkiller
Quote from: giantkiller on June 16, 2008, 12:44:32 PM
Here we have 2 pancake coils (Primary and secondary) fired by a stun gun circuit to produce the Lenz law of inductive repulsion. This propells an aluminum projectile.
http://www.americanantigravity.com/massdriver.shtml
Lenz law in action.
http://www.americanantigravity.com/bushman.shtml
http://www.rexresearch.com/roschin/pitkanen.pdf
http://www.americanantigravity.com/graphics/marcus/Toroid-Mag-Coil-Type2.jpg
The spin factor in the deyo coil and the searle disc show the same spinning / counterspinning layers.
Tesla mentioned his favorite coil was the conical. But where and how many times do we see it? He states that if we could only see the power in 3,6,9. You could stack 3 coils on top of each other and wired in series. You would have a conical shaped field and a wide band resonator. In the Colo spgrs coil the center is a canistor shaped primary, open wound. Same as the outside surrounding secondary. There are no descriptions or wiring photos to show how that is hooked up. It could also be done in 3 seperate layers. We just assume the obvious.
Anybody seen the Deyo tensor coil around in the sites?
The rotating mag field is the way to get the high speed energy instead of pulsing high speed. With 3 freqs the center focus can be exercised from the center and spun. The vortex center can be manipulated. The aetheric spin the becomes the dialetric moving across the copper windings and incorporating magneto-hydrodynamic inertia. A magnetic field can be created and spun anywhere. This gives rise to propulsion in any medium.
-giantkiller.
giantkiller
3,6,9. Tesla said it. Leedskalnin said it. Keely said t.
--giantkiller.
ramset
ERFINDER what will you do when others know your secret   why are you so cruel   to allow others to risk injury  and stand by with nothing but pokes and jabs   you do not wish to teach   you are an anomaly  you ask others to do what you yourself refuse to do ' tell me the answer and ill let you know if you are right' I am sorry for posting this GK and will remove it at your request[if time allows] but this  man  seems more a sadist  than a humanitarian
Thanks Grandma
PLUTOSBONE
Marko Rodin also said it 3 magnetic field, 6 magnetic field and 9 etheron flux field, 124 electric 875 electric. Map your way accross the universe.
Quote "9 is the height of natural energy"
The rodin coils are a flux thruster an (atom pulser)
thrusting the 9 into the 3 and 6.
"The ether has every attribute, It has a vector and a phasing a Pulsing and a surge etc it shoots out in 3rds from the center of the vortex and is the source of the non decaying spin of the electron"
"It penetrates everything, nothing can resist it, it leaves its reticulation pattern in everything."
we are about to see big changes
"Praise Jah You People" for he has taken his great power and begun to rule as KING .:)
