Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
sparks
   I think this could be what he would have found.  This is an in out compression/expansion of time that prevails in all mass fields.  You push it one way she slides down the inout vortex.  And pops right back when your done.  Meanwhile electricity is flowing (energy densisty intelligence exchange) all the while from both dimensional fields.  Far in excess of what is needed to push the inherent bounce towards your collector.  Tesla's elastic aether is already bouncing up and down the in out vortices.  Just need to push the plane at the right time in resonance with the inherent bounce.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Rosphere
Quote from: giantkiller on August 08, 2008, 02:39:44 PM
Had Farraday concerned Himself With The Mag.
FIELD SURROUNDING HIS Elec. current...
sparks
Think Legacy
Spread the Love
giantkiller
A collector then is a circuit element that has a usable, finite relaxation time. During that relaxation time, the trapped electrons are potentialized without movement as current; each collecting/receiving free electron gets a little gradient across it, but no current yet flows. In other words, during this finite relaxation time (collection time), we extract potential from the source, but no current. Thus we extract energy (potential), but no power (which is voltage x amperage). During the relaxation time, we extract from the source only a flow of VPF, which is continually replaced in the source by the vacuum's violent VPF exchange with the source's bipolarity charges. We do not extract power from the battery/source during relaxation time, but we extract free energy density. That free energy density, coupling with a finite quantity of electrons, gives us a collected finite amount of energy.
Instead, we are using the activated collector as a temporary, secondary battery. We will utilize this secondary battery in a conventional manner to power the load, which will also kill the secondary battery (dissipate its trapped EM energy). But that will not affect the primary source. The primary source is never used to directly power the load. It is only used as an infinite source of potential gradient (i.e., as an infinite source of energy density).
--giantkiller.
giantkiller
Here's the magic secret of free electrical power: The power in the external load is absolutely free, and it always has been free.17 In any load circuit, the only power you have to pay for, and have ever had to pay for, is the power you incorrectly use to kill your own primary source. The only power that "costs" more effort/dollars is the power erroneously utilized inside the source to "close the gate" and kill the primary source. Your electric power company doesn't pay for any of the collected energy on your load circuits that is dissipated to power your house. Instead, the power company charges you for its own ignorance. It charges you for its insane use of its own freely extracted electrical energy to continually kill the bipolarity in each of its generators, thus continually killing the free electrical source of that generator's energy.18
In any electric circuit, we can continue to indefinitely power the external load indirectly from a source, so long as we are not so naive as to use any of the free energy we extract from the primary source to dissipate back inside the primary source itself and shut it off!
And we can easily and freely multiply electrical potential. As an example, given a single good source of potential, a hundred radial wires can be connected to the source. The same potential will now appear at each of the ends of the hundred wires. A switcher/collector unit can then operate from each radial line's end, and power external loads, without "loading" the original primary source. This "cascading" can be continued indefinitely. A single power plant, e.g., can power the entire electrical grid of the United States. And a single automobile battery can power a large, agile, electric automobile at highway speeds, with sports car acceleration, with unlimited range, without "refueling," and with no noxious chemical exhaust.
Sounds like what Tesla did with his car.
So at resonance we get the full potential, no current spike in the green box. Then shown in the red box, current flows(where the self-defeating parasites live). We then should not use the current side but the potential side of the wave. The spike keeps pushing more and more potential in the mag field. The cap keeps storing more and more of the gift. Anybody ever seen a cap 'cool charge' hundreds of times higher than its rated capactiy and not get hurt?
Keep hitting the coil at resonance and use that potential spike for energy. The field exits the coil and hits another coil in resonance and they chime together. One can always use the CEMF as an added benefit. The initial pulse and the CEMF both have relaxation on the back side of the pulse which is much faster.
So make a tank circuit with the cap or other caps in reverse inside the coil.  That would be easy to hide.8)
--giantkiller.
