Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
acerzw
In a Holographic Multiverse everything is smoke and mirrors!
What is Reality? Improve yours: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13459
A shorter version for the very open-minded: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13866
hansvonlieven
G'day all,
Interesting set up Giantkiller, very reminiscent of Keely.  This will work if you get the waveform and the relative amplitudes between the three amplifiers right.
If you have not already done so I recommend reading up on Keely. A good place to start is my website http://www.keelytech.com Plug -Plug :-)
But seriously, Keely says that there is unlimited energy available if the right combination of three audio flows can be achieved and the correct overtones created. The secret appears to lie in the fantastically high vibrations that can be generated by heterodyning the correct audio streams. Worth having a look at.
The purity and compatibility of the audio streams are of paramount importance, otherwise unwanted beat frequencies and nodal interferences crop up in the system.
Good luck
Hans von Lieven
giantkiller
bolt
GK thats good the setup must be clean first before moving forwards. Keep your leads very short use coax between boards. Wrap any long PSU cables through ferrite rings in case any RF is picked up.  Once it sounds nice do bandwidth test and measure -3db points i been interested to know how far up this goes. Then calibrate each amp for precise amplitude then check again at 10 Hz 10k 100k
bolt
If you still get unstable condition later after taking basic steps yourself please do a video and show use the effect. Depending what im looking at i have ideas to cure it:)
