Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
armagdn03
Simply a suggestion.....
It would seem that we are making theory and conjecture before the fundamentals are understood. Nothing wrong with that as it is part of the learning process, but......(and this is only my opinion of course!).......
There are a few on this forum who have given complete solutions to what we seek. They have given hints, plans, and more. The problem is that the people evaluating and rebuilding, do not understand the function of these devices, and so have very little hope of getting them to work. So what happens? they throw together a model, it doesn't work and they move on to something else, only to be disappointed once again. A person could spend a lifetime in this self defeating cyclic process. They key to understanding is knowledge of the fundamental energy unit, knowledge of electricity.
So this is what I propose.....
In light of what you have uncovered so far......what is magnetism? what is "static electricity" what is gravity, and how might they all be the same? (acerzw....3d!!!!)
"Positive charge attracts positive charge and expels negative discharge.  Negative discharge repels both negative discharge and positive charge." Walter Russell
What does this mean? it does not fit with most peoples views, why?
What If I were to say "the male force polarizes, the female force depolarizes" or "Gravity polarizes, radiation depolarizes"
How does this fit with our views on EMF and BEMF?  What is BEMF?
If we place a hot iron on one side of a room, and ice on the other, is there an electric current present? If the hot iron is radiating, is it male or female? if the hot iron is getting is increasing in energy, is it predominantly male of female, concentrating or decentrating?
How do concentration and decentration interact?
I see alot of pretty pictures with no talk of what they mean........ its not enough to accept that something may be true, the truth is self evident, hence your study into these brilliant men, but lets try and actually understand energy before harnessing it.
I wish I could turn my brain off sometimes, then I could get some sleep.
Grumpy
Quote from: armagdn03 on December 23, 2007, 12:59:59 AM
Great post!
        -Frank Edwards
Shanjaq
"Positive Charge" equally and simultaneously emitting and absorbing, while "Negative Discharge" only casting reflections?  It would seem impossible to directly observe "Negative Discharge", only the effects of its presence on emissive/absorptive processes(reflections that modulate cyclical "Positive Charge" effects by phase-interfering?)
armagdn03
Quote from: Shanjaq on December 23, 2007, 04:07:22 PM
positive charge is the polar opposite of negative discharge, the same way emission and absorbtion are polar oposites.
But if Positive charge does both simultaniously, then so must negative reflect that, in that it must be simultaniously doing both as well, for all is balanced.
Perhaps this is where you were going, but to say that it "only casts reflections" is giving it the short end of the stick, for it is equal and opposite to positive, and just the same one could just as easily say that positive charge is only the reflection of negative discharge.
giantkiller
Updated..
Here is the secondary coil of the trigger stage.
Slight changes along the way will happen.
For instance, if the ring were to be put at the other end and triggered. That would create a magnetic field surging up through the center coil. That field would hit the firing ring like a magnetic field feedback loop. Whoa...
