Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
sparks
     This configuration is the same as a cyclone.  The power in the slow spinning greater mass of the clouds being transmitted to a very high speed spin on the ground.   Orbital momementum transfer is all it is.  Electrons have mass and carry charge so they will obey every law of physics just like an air molecule.  I don't care how small they are they are still mass.  The only difference between them and other mass is their charge.  You cause them to bump up and down in a wire you create vibrational inertia.  You make them go in orbit they create orbital momentum or inertia.  The proton 1800 times more massive then the electron but equal relative charge.  That proton doesn't have anymore inertia in it than the tiny electron.  Lots more potential energy but same inertia.
      Earth has a shitload of electrons all spinning in the same direction relative to the Sun. So it has a huge magnetic field that interacts with the magnetic field of the Sun.  And the Sun is orbiting the galaxy center.  Which by all indications has a big old magnetic field enough to stop the solar wind dead in it's tracks.  Just one electrical vortex after another.  This is why the Corona of the sun is hotter than the surface of the Sun.  The sun is getting it's energy from the Corona as it traverses the magnetic field of the center of the Galaxy.   Potential Energy being transferred on huge wavelengths that can only be observed by huge bodies of mass.  But I digress lets get these tpu's spinning!
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Feynman
Thanks sparks
Here are the results of tonight's experiments involving the NE555P  (555 timer).
I have conducted a second trial of the experiment 'rise and time'. The scope is now properly calibrated. All the components and tests are otherwise identical as before. This is a test of the radio shack version of the 555 chip. The objective is to understand it's oscillation capabilities.
Question: Does circuit frequency effect the rise time of the NE555P ?
Answer: No. Frequency does not affect rise time in NE555P chip.
Question: Does this mean all oscillator chips have constant rise times?
Answer: Insufficient information to answer this question. Probably not.
Question: What is the rise time of the NE555P.
Answer: The rise time is constant and is approximately 110 ns.
Question: Is this fast or slow?
Answer: Compared to the newest chips (LTC6904), the NE555P is very slow.
Question: Why does this matter?
Answer: Switching speed is important for sharp gradients, which are necessary to cause curvature of local spacetime. Futhermore, sharper gradients mean the signal has richer harmonic content. This will be important for research into resonant and scalar physics.
Question: How do I know the rise time is for sure 110ns ?
Here is a scope trace at high frequency (approx 285khz, T/div=0.02us, V/div=1V)
giantkiller
Quote from: Feynman on March 11, 2008, 07:36:30 PM
wow , nice diagrams guys
i don't understand this yet, i think i'll need to experiment once parts get here.  needless to say this is very exciting.
The 555 to a Fet is the start. Don't try too hard to analyze it. This is the driver to a multistage coil winding. Look at
http://www.overunity.com/index.php/topic,1872.msg21431.html#msg21431 and further on. Now this is not the end of end all but...
This will show you the next step of multiple coils mobius hooked up into inductive coupling. The control windings are 90degrees to the iron wire and parallel to the outside low inductive winding.
Here a some stun gun ckts. Notice the LC tanks and coupling.http://www.personalarms.com/schematics.htm
And here is my favorite: http://www.emanator.demon.co.uk/bigclive/stunner.htm
This most likely adheres to Telsa's patents. Notice the internal spark gap. We only ever see the external spark gap at the end of the transformer stage.
Now we have the clock stage, the transformer stage, and the 3rd stage is where we want to be. Remove the sparkgap at then end of the transformer stage. There you will find the High speed voltage that Tesla mentions in numerous patents. ;D
--giantkiller. Telsa patents... The real breakfast of champions and small gods too. :D
giantkiller
I chose the xr2206 generators to work with very low range under 200hz besides above per the attached excerpt.
The 555s also work. but they are chatty. This is a big clue here. If you want stability then these are not here. The chatter can be up in the 100mhz with heterodyning so you'll have one very snappy critter. It is a good thing I used inline resistors to squelch the current. Let's just call it a magnetic stun gun. Hence the pain I experienced last year. Anybody can jump in here and you are free to get hurt.
The other oscillators previously posted are also necessary. I will incorporate them in a sub build. I too like the high speed.
Now that this platform is established let go another step.
The articles publish the low freq of < 100hz. That is what I want. I can not stray from Keely's work. It is drivng me. But I also can achieve these low freqs by heterodyning. So we have a brute force single freq or a harmonically produced one. I am under the suspsicion that both are valid but produce different effects. John Hutchison's tests come into play here also.
So basically I have this narrowed down. The builds are now the time consumer. I have two paths for the freq generation, not including 555s. Besides the xr2206s produce sine waves also. ;)
Ok. Lets have some fun here. Get familiar with the BFG. I can use the spiral drive to produce an angular one chord and shift over to the next vertical triad and drive that spiral connection with another chord. And I do this the 3rd time for the last set. So as the chords are pumped into each triad, the magfields twist into a center pressure zone. ;)
I can use the center Tesla coil secondary to read this and then fire that primary, shooting a high speed field into the center pressure zone.
See this? Should be fun.
--giantkiller.
