Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
0 Members and 26 Guests are viewing this topic.
giantkiller
Besides the currents generated in the secondary coils by dynamo-magnetic induction, other currents will setup in the same coils in consequence of any variations in the intensity of the poles in the ring A, the iron core.
When this is done, the currents are produced by dynamo-magnetic induction only, the same results being obtained as though the poles were shifted by a commutator with an infinite number of segments. Whoa! :o
--giantkiller.  Onward, gentlemen and ladies. ;)
giantkiller
Quote from: Spider on May 08, 2008, 05:00:44 PM
Hey GK,
A little side-experiment.
My car is running on liquid propane, and I had to fit a shutoff relais for MOT.
The relais is there to shut of the gasflow when the engine is stopped by a crash.
It is triggered by a simple wire wound 8 turn around the spark lead from the ignition coil, with no connection to ground.
This afternoon I was curious, because my investigations with tpus how much voltage that wire would give. So I shorted the relais, started my car and messured the voltage with my Digi meter.....more than 200 VAC ...VDC could not messure.....And it destroyed my meter BTW..... :(
How is that for feedback from a spark....
Now I see what you mean by 4 tesla coils...might work..
Greetings Rene
I am around too, waiting with interrest!
Well if 8 turns does that then by no means increase the turns or gauge! I mentioned doing this last year and can't believe somebody would do it. LOL. Good job! I should have mentioned before 'Do not do this at home!'. Well you can just drive down the road a little ways.
Let's see: Stun guns, flybacks, ignition coils all blow up electronics and they all have the same thing in common.
--giantkiller.  Tonight I wind the outer layer of soft iron wire onto GK4. Baby gets new shoes. I might call this by a new name, i.e. NT382282 :D
sparks
      @gk
  That device is basically a choke but instead of the kick permeating an air core or ferrite bead it's magnetic disruption permeates a special transformer winding.  Same frequency same current 20,000
gain in voltage.  See below.   Lots of good things can happen by moving the magnetic field with kick displacement energy.  I don't know if any iron is needed to get the kick moving the magnetic field inward across the pancake secondary. ???
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
innovation_station
well my new toys just arrived just got back form picking up my big reeds got 10 of em  ;D
also when i was down in the city i ordered a new tool  ;D  it is a simple small multi meter that hooks into your pc it does almost it all lol
but the best thing it does is inductance  :P
it will read freq up to 10 meg too i get her next week
ist
giantkiller
Quote from: sparks on May 08, 2008, 07:16:36 PM
      @gk
Yep. Another way to get a magnetically contained and compressing shockwave.
I have seen, heard, read about, and quoted to us, this squeezing. I have 3 of those pancakes and they do things. That was 18 months ago. Leedskalnin has quite an explanation about the flux too. The course I am on now is to make the NT382282 exactly. Telsa and Leedskalnin both mention the iron casing. I goto follow this path now. Telsa also showed the NT382282 in numerous patents. Call me a 'Magnetic pitbull'. I saw what happend with the GK4 rendition of the NT382282 minus the iron casing. This should up the ante. Leedskalnin and Tesla specifically mentioned covering the coils with soft iron. Soft iron is easily permiated by the electro-magnetic waves and holds the flux while maintaining the North South alignment, quote Ed.L.
I start tomorrow with coil kit in hand and crank one out. Any cost in money or time for a single inkling of progress. Because that is the fuel for the next step.
horizontal iron wire core inside of 28gauge coil inside of lamp wire inside of vertical iron wire coil. The 2 iron coils alter the vector through the magnetic field.
--giantkiller.
