Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
armagdn03
I was about to write a comment on a particular post, but decided I should read the rest afterwords first to see if I had missed anything. Then I realized,
YOU GUYS DONT KNOW WHAT  YOU ARE TALKING ABOUT! and honestly, I mean that in the most kind way possible.
I already took the risk of sounding like a complete jack ass, and probably succeeeded, but dont get all in a tizzy yet. I have talked with a couple of you, you are smart guys, you know your stuff, but here is what I see. You know the many pieces of the puzzle well, but you arent putting these many pieces together!!!
For starters, you CANNOT seperater the electric field from the magnetic field
Keeping this system in mind, you CANNOT have inductance without capacitance, or vice versa
Looking at the PMH, the "Orbit" of the magnetism in the U bar and the Keeper is "broken" when you pull the Keeper from the Bar, what does this create? A change with respect to time in the magnetic field. This in and of itself generates a voltage, where there is a voltage there is an amperage...........Voltage and amperage are unseperable, you CANNOT have one without the other! The faster the keeper is pulled off, the brighter the bulb, WHY?
What role does iron play? If we were to look at the fiberous construct of the magnetic field it would look as though it were an onion with many layers. Iron packs these layers into closer proximity, it focuses them. Keeping this in mind what role does irong PLAY??? If we are trying to harness the Magnetic field (which is the same as the electric field) in a coil, we want the maximum change in field to occur around or inside the coil. Enough of this iron vs copper crap! what does each do!!!!!! the iron focuses the magnetic field in close proximity to the copper, so that when a change in flux with respect to time occurs, the copper is right in the "middle" of the situation.
I could go on and on, but lets keep it simple, you know what each does, now start thinking about how they interact rather than guessing at new things to try. Then you can start building, and stop experimenting, build with knowlege!
(sorry again for being an ass)
I wish I could turn my brain off sometimes, then I could get some sleep.
giantkiller
@Loner,
Thanks,
I like to think I have been open and honest with tests that really bode well for others, not myself. I know what I got. And keep it in simple or at least some product oriented terms we understand. But that takes time between results. Poking in the dark at a secret is tough. Nobody is a hero, just a trooper.
Bolt pointed me towards the heterodyning and sent a circuit to make. It didn't take a rocket scientist to see the writing on the wall. Actual help. Which so many have not even understood when it hit them. We all must respond with what ever piece of results one comes up with. The noise might just be a smoke cloud to protect whoever breaks the code. That would be a good thing. :)
@armagdn03,
I had posted about the where the copper sits in the interaction. Sorry if it wasn't clear enough.
--giantkiller. I press on as always despite the angry hoards.
sparks
HI ARMA long time no hear :)
   Iron has the abiltiy to rearrange it's atomic lattice in response to a magnetic field disruption.  It gives the magnetic field direction.  Whereas the copper is converting it's potential energy into a magnetic field disruption.  The dielectric or charge state only comes into play to distribute the kick disresonance.
After that it is all about what happens to the magnetic field surrounding your collector.  You will note that to get voltage all that is needed is to move a conductor through a compressed magnetic field. Or move a compressed magnetic field through a conductor.  Nice to hear from you.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
giantkiller
Notice the symmetry? No small ringing.
All 3 copper coils in parallel and all 3 steel coils in series on an iron wire and magnetic core. Only 600ma.
Next test will be 4 coils hooked the same and I replace the 555 with a xr2206.
The sequencial postings have shown and reinforced waveform improvement.
No fantasy here.
When the pulse collapses the flux is squeezed. The ramping up in the ringing is the flux field recovery.
--giantkiller. Got progress?
sparks
  Thats a nice full oscope shot if I've ever seen one.  No dinky sinsuoidal output from GK's machines.
And the eyes in my head see the world spinning round right there on GK's oscope.
Think Legacy
Spread the Love
